Sound bar setup, only one input help
limsol45
limsol45 Posts: 2
Hello, I have a sound bar that has only one red/white input. My tv doesn't have an red/white output, just an optical one. I currently just have my satellite box hooked up to the sound bar, but I would like have my gaming systems hooked up too. What are my options to do this?
  • nguyendot
    nguyendot Posts: 3,596
    edited December 2010
    Purchase a switch box, or something with more inputs.
    Main Surround -
  • limsol45
    limsol45 Posts: 2
    thanks, is there one that you would recommend?
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Any RCA to RCA switch box will work. You should be able to find one at any store that carries electronics.
    This will let you connect multiple sources to the switch box, and then run just the one pair of cables to the soundbar. Then you'll be able to switch between the sources with the switch box.
    Shouldn't be too expensive...I picked one up at Best Buy a couple years back...it was only like $15-16 IIRC.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
