Can I use Microphone with HomeTheatre???
tghorai
tghorai Posts: 4
edited January 2011 in 2 Channel Audio
Hi,
I have POLK SurroundBar 3000 Instant Home Theatre. Can you please help me what I need to make it a "Karaoke system/Singing Machine". Do I need to just buy a microphone ? and then how? if so what type of Microphone?
Thanks in advance for the help.
Regards
Tanmay
Post edited by tghorai on
  • nguyendot
    nguyendot Posts: 3,594
    edited December 2010
    You need a karaoke machine.
    Main Surround -
  • madmax
    madmax Posts: 12,434
    A karaoke machine would make life easier. It has reverb and other effects to make the voices listenable and has a microphone feedback eliminator to eliminate squeeling from the speakers. Here is just a feedback eliminator http://www.zzounds.com/item--BEHDSP110 but by the time you add some reverb and a mic you will have more in it than a dedicated machine.
    Vinyl, the final frontier...
  • Tour2ma
    Tour2ma Posts: 10,177
    madmax... the karaoke king of Club Polk???
    More later,
    Tour...
    Vox Copuli
  • comfortablycurt
    comfortablycurt Posts: 6,745
    It's not too advisable to use home audio speakers as a karaoke machine, or for any other kind of live sound. Live sound puts stress on speakers that recorded audio generally won't.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • madmax
    Tour2ma wrote: »
    Nah, I used to have a friend who was into it. He couldn't sing either.
  • Tour2ma
    Ok, mm, but if you change your mind I don't think it would take much to claim the title...
    :confused::confused: Please explain...:confused::confused:
    More later,
    Tour...
    Vox Copuli
  • organ
    organ Posts: 4,969
    Go to one of those Asian stores that sell all kinds of electronics dvd's/kareoke, etc. You should be able to find a kareoke dvd player with mic inputs w/adjustable volume control. They're not expensive. My parents got one while looking for a cheap dvd player. Check out China Town or something.
    I know there are units that can take out the vocals off normal cd's. I don't know if these dvd players do that. If not, you'll have to buy kareoke discs.
  • thuffman03
    thuffman03 Posts: 1,325
    How can you stand Karaoke? It never sounds good.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • madmax
    Live sound (if not manipulated) puts great stress on loudspeakers because of no dynamic range control, such as in the case with a microphone. Our pitiful audiophile speakers would not stand a pure square wave of any real amount of power for any length of time. Yet another reason the dynamic range is so compressed on all the recordings. Imagine a pop when you say a p word to close to the mic, or the frying of tweeters when you have a good long ssss word.
  • comfortablycurt
    Tour2ma wrote: »
    madmax basically sums it up in his post:
    madmax wrote: »
    Pro audio speakers are designed to handle the stresses that live sound puts on them. That's not to say that you're necessarily going to damage your speakers by using them for karaoke, but the likelihood is quite high. It certainly won't do much to prolong the lifespan of your speakers, if nothing else.
  • Audioquest
    Audioquest Posts: 104
    thuffman03 wrote: »
    It does if you add this...one bottle per person, just don't admit it the next day!
    captainmorgan_original.jpg?1201635160
    HT: Polk SDA SRS 2.3 main fronts, Klipsch RC-25 center channel, Polk RTi-150 rears, M&K V1B sub, Denon AVR-5800, Samsung 52" LCD, Sony BDP-S550
    2 Channel: Carver ALS Platinum, Audio Research LS-2B preamp, Counterpoint SA-100 amplifier, Integra CD player, Denon SL7D tt, TC750 phono pre, Nikko tuner
  • madmax
    I think I would need something a little stronger, maybe some crack.
  • Tour2ma
    edited January 2011
    Mood altering substances... the real source of home audio danger...
    Still chewing on the square wave, sibilence thing. Makes sense from standoint of clipping anywhere in the audio chain is a bad thing (even DAC's which I'd not considered before).
    Sorry though, not buying the pro speakers are built to take it bit... Built to take the rigors, bumps and tumbles of the road sure, but sound damage protection has to be a product of the soundboard.
    More later,
    Tour...
    Vox Copuli
  • comfortablycurt
    edited January 2011
    Tour2ma wrote: »
    The soundboard is a big part of it...and for that matter, your home audio equipment doesn't have the kind of protection circuitry that a live soundboard has.
    Home speakers can't take the kind of audio abuse that live speakers can though. They simply aren't built to handle that kind of stress. I have a modest PA system, and for a long time I tried using home speakers on it. I used several different ones over time...some Technics 15" 3-ways, a couple different Cerwin-Vega's and some other various speakers. Without fail, I eventually blew the tweeters on every pair of home speakers I used in my PA system. I've got a pair of JBL pro speakers now that I've had for about 3 years, and I've thrown more volume at those things than I ever did at any of the home speakers I used with it, and I've never even had the remotest fear of blowing the tweeters. Being able to handle more wattage is a big part of it. Also notice that nearly all pro speakers use some kind of horn tweeter, and not dome tweeters. Horn tweeters in general are much more capable of handling ultra-high frequency harmonic overtones than a home audio dome tweeter can. I'm not a speaker designer, so I can't give you technical reasons. What I can do, is speak from my own personal experience, and from the accumulated experience of many of my friends who are also musicians(as am I). Home speakers simply aren't built to withstand the abuse that live audio can put on them. On the flip side though, pro speakers aren't capable of resolving as accurate of a reproduction of an audio signal as a good pair of home speakers.
    thuffman03 wrote: »
    It's not really supposed to "sound good". It's supposed to be fun...which it is. It's fun getting up and making an **** of yourself with a bunch of your friends singing your **** off to cheesy **** songs.
    I'll also add that chicks like a guy that will actually get up and make a fool of himself by singing some karaoke. It shows that you have a lot of confidence, and you're comfortable with who you are.
  • Tour2ma
    edited January 2011
    I can live with that...
    But I've heard the Altec Lansing Voice-of-the-Theaters I rocked live to in my youth in some kick-**** home 2-ch rigs...
    More later,
    Tour...
    Vox Copuli
  • newrival
    newrival Posts: 2,017
    edited January 2011
    did someone say karaoke? I think erniejade needs to impart some wisdom on this subject... :biggrin:
  • newrival
    edited January 2011
    Your level of fun at Karaoke is directly proportionate to the amount of booze consumed. I've really enjoyed me some karaoke
  • Joe08867
    Joe08867 Posts: 3,919
    edited January 2011
    newrival wrote: »
    Amen to that...
  • madmax
    edited January 2011
    Tour2ma wrote: »
    Most pro speakers can take a continuous square wave of massive power given the 800w to 1800w rms coil ratings. The suspensions are massive as well. When something breaks the whole mess explodes apart, not a quiet little pfft like audiophile stuff. :biggrin:
  • Tour2ma
    edited January 2011
    OK, mm, now I'm starting to buy it... built for speed, not for comfort... kinda to opposite of.... me...
    So with all their beefiness, they just can't do subtle? But the VOTT's I referred to could do subtle?
    More later,
    Tour...
    Vox Copuli
  • madmax
    edited January 2011
    Tour2ma wrote: »
    Never said they can't do subtle but that they must do blunt force. One doesn't necessarily negate the other.
  • Tour2ma
    edited January 2011
    Never said that you ever said that I... getting dizzy...
    You're right... My old bean mashed this thread together with the pro v home amp thread...
    Thanks for hanging...
    More later,
    Tour...
    Vox Copuli
  • madmax
    edited January 2011
    I never said you said I said that either. :biggrin:
    A few months ago I bought some 15" pro drivers to mate with some ancient Altec horns. The woofer itself seemed to have a pleasing detailed sound to it but I have not put in the proper size box yet.
    Probably time to let this slow dying thread fall to the bottom of the sea. Nice to see you back Tour!
