Building a couple of subs..........
I would like to build a couple of sub/stands for my PSB Alpha's.
I am thinking about using an 8" in each sub/speaker stand.
Heres where the confusion starts:
I'm thinking bandpass without a crossover!
There, I said it, and I feel better!
Please leave the room, if you feel uncomfortable.
Seriously, I would like to pick up some punch/dynamics in the 120hz & below/region to compliment the Alpha's.
I think it would look pretty good with some Totem like "Beaks", or outriggers.
Alittle wider than the Alpha's
Points comming out of the top of the sub/stand for the Alpha's to rest maybe?
Yet another perk, UNDER $100 FOR 2 (no x-over:biggrin:!!!!).
BAM! Up another notch!
Keep in mind the small dimensions of the boxes in the link below.
I would be running both subs, and Alphas off a Rotel 960bx.
60 watts (per) dual mono, with separate power supplies.
It'll run 4 ohms easy, and tested in Stereophile @ over 200watts into 2 ohms comfortably.
I would run the sub/speaker stands in parallel with the Alpha's (gaining some power).
Just worried about it not being "fast enough" for the Alpha's
Here is what I am looking at, please comment on the perimeters and look for any possible problems.
4.8 ohm.
Keep in mind no inductors, or caps to buy to achieve a steeper slope.
https://www.madisound.com/store/product_info.php?cPath=45_228_257&products_id=8991
I should mention they are Alpha B1's that I bought brand new, and have maybe 200 hours on them.
Running the Rotel with a B&K Ref 20 pre (sub preouts if I decide to go powered).
4.8 ohm.
May want to take this over to the hometheatershack forum. They are very knowlegable over there.
Sounds like an awful idea."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
