Help with Center Speaker
sirishg
sirishg Posts: 2
edited December 2010 in Vintage Speakers
I have Monitor 60s in the front and PSW110 SW. What is the best option for me to go with center channel? CS10 or CS20? Some say CS20 is wayyy better. Other I read CS10 is enough. Pls help
Post edited by sirishg on
  • B Run
    B Run Posts: 1,888
    sirishg wrote: »
    The cs10 will work fine, however if you have the room for it and the extra $ the cs20 is really a better center channel.
    WELCOME TO CLUB POLK!
    The main reason most of us will tell you to go BIGGER on the center (CS20) is because it carries 50%+ of the sound in a surround soundtrack. So obviously it is the most used speaker in a surround set up...you want to be able to do two things:
    1. Hear the dialog clearly and
    2. Hear MORE than just the dialog...because there is more on that track.
    cnh
  • DanAckerman
    DanAckerman Posts: 70
    +1 to what cnh says.
    He recommended to me over a year ago that I get the CS20, but I had already gotten the CS10. A year later I got the CS20 upgrade. The CS10 is a good speaker, but the CS20 is just a better speaker.
  • sirishg
    sirishg Posts: 2
    Thank you everyone!! Decided now to go with CS20
  • jimmydep
    jimmydep Posts: 1,305
    Good Move. Welcome to the Club!!!
