Match a Denon AVR to RTi A7
I just got the Polk RTi A7 speakers and a Csi A6 center ch, currently they are hooked up a Denon 2802 AVR, but I want to upgrade to a Denon 3311 AVR. What does the forum think? Good choice?? Btw I upgraded from a 15 year old Polk audio RM 3000 speaker set, with Boston Acoustics VR12 center ch.
Sytem List:
Denon AVR-2802
Polk Audio Rti A7
Polk Audio CSi A6
Polk Audio LS Fx Rears
Mono Price speaker wires/cables
Sony PS3
Xbox360
HTPC with Boxee
www.boxee.tv
www.monoprice.com
Denon AVR-2802
Polk Audio Rti A7
Polk Audio CSi A6
Sony PS3
Xbox360
HTPC with Boxee
www.boxee.tv
www.monoprice.com
Post edited by svx9494 on
What you will gain from getting the 3311 is room correction and HDMI connections. HD radio and a few other features. There is a slight difference in power but nothing you will notice.
The 2311 would work too. You just loose the phono inputs and a few watts.Things are more like they are now than they ever will be! -
That VR12 center you had is no joke.. I still run one in my bedroom. 3 way monster of a center channel.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
I've got that exact combo ...RTi A7s, CSi A6, Denon 3311. Great receiver, and has pre-outs if you want to add one or more power amps. Currently, only powering the surround speakers w/ the 3311, but still the Denon is a good match.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
I can relate. I have the 3 way VR-920, this CC is huge and it sounds great.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
