marantz pre for my 500Us?
scottyboy76
scottyboy76 Posts: 2,905
edited December 2010 in Electronics
I have two extra marantz ma 500U 125wpc amp
A two channel rig is just a preamp away.
I have some speakers and a few shotguns and hand cannons i could selectively part with. and maybe get 150 bucks together.
should i try to locate a marantz to pair with amps.
if not, what good pre can i expect for this kind of money.
any info would be appreciated.
humpty dumpty was pushed
Post edited by scottyboy76 on
  • scottyboy76
    thanks all
  • megasat16
    megasat16 Posts: 3,521
    thanks all
    Did you find the pre for the Marantz or you just gave up the search of the preamp under 150 or you lost patience waiting for reply to your thread?
    As far as I know (but have no personal experience or own one) MA500u is made for use as both stereo or HT amps. You could probably find an old Marantz receiver from that era if you want a close matching Marantz pre.
    But you could use any stereo preamp with it or AVR with preout or processor. You can get some Carver Preamps, B&K preamps, some Pioneer (silver face) or Acurus preamps around $150. You need to search eBay and Audiogon diligently.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
