The truth behind Home Depot!
Jstas
Jstas Posts: 14,985
edited December 2010 in The Clubhouse
Sadly, for me, this is typically my fate. Except for the wrong parts.
Expert Moron Extraordinaire
Post edited by Jstas on
  • WilliamM2
    WilliamM2 Posts: 4,807
    So true. I had to replace the seal between the tank and bowl on my toilet. I decide to buy a complete repair kit and replace everything in the tank as I needed a new fill valve anyways as it was filling very slowly. And having everything would save me going back for parts, right?
    So what happens? The first turn to loosen the tank from the bowl, the bowl cracks. Now I get to go back and buy a whole toilet. No longer need the repair kit.
  • bobman1235
    bobman1235 Posts: 10,822
    Yup. Don't think I've ever been there just once.
  • nguyendot
    nguyendot Posts: 3,594
    I agree. Happened so many times since I've bought my house.
    Main Surround -
  • xsmi
    xsmi Posts: 1,801
    And I thought it was just me.
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    If you're having to do any kind of plumbing repair, it's almost guaranteed that you'll be making several trips to HomeDepot/Lowes.
    Installed a garbage disposal several months ago, and sure enough: thought I had/didn't have part/tool/etc, so it was back to Lowes.
    Avoided the final trip when the decision was made, "Fug it !" and broke out the JB Weld.
    No leaks yet !
  • mrbiron
    mrbiron Posts: 5,721
    I'm pretty sure HD is going to start charging me rent. I'm there guaranteed once to twice a week and it's not even for work.
    Ran out of sheetrock.....ran out of sheetrock screws....my drill died.....ran out of sheetrock screws. Now i buy the screws by the 5lb box just to be on the safe side.
  • Jstas
    Jstas Posts: 14,985
    It's not just Home Depot either. Car parts stores and ever Radio Shack when they sold stuff worth while.
    What was REALLY a drag is when you bought everything of the part you needed at Shack and still needed more so you had to go to a place like Circuit City. *shudder* They usually had the part (wires, power fuses, stuff for car stereo) but you had to deal with Captain Skippy the Salesdude who knew everything about everything but really knew nothing.
  • concealer404
    concealer404 Posts: 7,440
    I have the same problem with Summit Racing and Jegs. I always seem to miss a fitting or not order enough AN lines by a matter of inches.
    When i'm rich, i'll just stock my own warehouse of the stuff.
  • phipiper10
    phipiper10 Posts: 961
    Always buy both parts, you know you will be back for something else later and you can return the "wrong" one then!
    Yes, 2 and 3 visits are not uncommon when I attempt a seemingly simple project!
    And let me throw out an "H to the IZZO!!"
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • RuSsMaN
    RuSsMaN Posts: 17,986
    I replaced the kitchen faucet recently, and did it ALL from Walmart. It took two trips though.... ;)
  • madmax
    madmax Posts: 12,434
    RuSsMaN wrote: »
    Isn't that kind of like the joke of "Russman buys his clothes at walmart" :biggrin:
    Vinyl, the final frontier...
    I'm not particularly handy. But in a variety of home projects, I've found that dealing with your local, perhaps smaller and (been around LONGER), hardware store that not only are their people more knowledgeable but you DO develop a relationship with one or two of them who then can even hand you what you need before you even ask them because they remember what you're doing and have already figured out how competent or, in my case, incompetent you might be.
    Fortunately for me...there's a good store just around the corner about two blocks.
    cnh
  • RuSsMaN
    I buy my duds at Goodwill. ;)
  • greyford1979
    greyford1979 Posts: 749
    I only live 15-20mins from Summit Racing...so I can at least drive back there the next day:biggrin:
    I love animals, they're delicious!
  • amulford
    amulford Posts: 5,020
    RuSsMaN wrote: »
    Well at least you'll know what to get when you replace it next year:eek:
  • sandworms
    sandworms Posts: 1,043
    they know me by name
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Story of my life!
    Toolfan66 Posts: 18,067
    I always buy more then what I need, and still have to make a second trip. I like having extra stuff at the house, every now and then you get lucky and have it in the garage.
    1/2" copper tubing,fittings, and solder?? I always have some around.
    Pipe tape and dope? Check
    Sprinkler heads?? Check
    Thermal Coupler??Check
    Ball Valves?? Check
    and a bunch of other crap!!!
  • Jetmaker737
    Jetmaker737 Posts: 1,118
    Better that than Lowe's!
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Yep! That's me too!
    The thing I love the most...is how you can't find the tool that you need, you tear the house and shop apart trying to find it...and it's just not to be found. Then you go and buy a new one, and two days later you find the one that you already had when you aren't even looking for it.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • phipiper10
    ^^^ I''ve purchased extra Flashlights, hammers and razorblades/box cutters only to find the missing one a couple days/weeks later.
    Fun, I now have them in my basement, garage and with the camping gear! And the kids even get a flashlight now too!
