How do you check for speaker seal on SDAII's
Rookie
Rookie Posts: 20
edited December 2010 in Vintage Speakers
How do you check speaker seal on SDAII's, and if it's bad what is the most common problem and how do you fix it?
Post edited by Rookie on
    F1nut Posts: 50,761
    Push the PR in and hold. The mid-drivers should slowly recede after a few seconds. They will fully reseat after you let the pressure off the PR.
    Tigthen the screws.
  • skrol
    skrol Posts: 3,393
    Are there any cracks in the cabinets (ie. the seams)? If so, they need to be sealed.
    A favorite fix around here is; using Moretite as a gasket instead of the foam around the drivers.
    If you tighten the screws, just be careful not to over tighten. Otherwise, you may strip the holes. There are fixes for that too.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    F1nut Posts: 50,761
    Unless your foam gaskets are damaged, I do not think Mortite is needed and even then there are other choices.
  • Rookie
    Rookie Posts: 20
    I pushed the PR in and the drivers popped out and returned to a relaxed position as soon as I took my hand away, if the cabinet is sealing they should stay out a few seconds, correct?
    The cabinets are in excellent condition. Do you think it's the foam gaskets around the drivers?
    F1nut Posts: 50,761
    Push the PR in and HOLD. The mid-drivers should slowly recede after a few seconds. They will fully reseat after you let the pressure off the PR.
  • Rookie
    Rookie Posts: 20
    Got it, mine look good. Thanks!
    F1nut Posts: 50,761
    Atta' boy. :smile:
