sub direction
paul mx3
hi....
im just in the process of doing a full install on my car...mazda mx3....i dont want to lose too much boot space so was thinking of building a fibreglass box for the sub that will mould into the corner of the boot behind the wheel arch.....this would give me the option of having the sub...a polkmomo mm100 firing accross the boot or possibly diagonally acrross the boot space....is there a best direction for the sub to be firing or should this be ok....thanks:D
Post edited by paul mx3 on
try to get it to fire AT something -- a sub firing right at the listener will not be too good... bass has to "bounce" off something before its really heard... if you can work around that, then by all means try to.The Artist formerly known as PoweredByDodge
