f/x300i height placement
mjgol72
Getting ready to pull my polk system out of the closet to install in finished gameroom. I have the f/x300i's and it has been 6 years since they were installed in previous home. I can't remeber what is the recommended height for install????
Getting ready to pull my polk system out... I have the f/x300i's and ...I can't remeber what is the recommended height for install????
Hey mjgol72,
Welcome to CP....I am just a mere Newb here but I will share how I have my front stage set.
I have read (not on here) that all 5 or 7 or 9 ch should be in line with one another. (heigth wise) but as you see, my system is not following that equasion. However it does fulfill my situation.
I set the heights of tweeters on the frnt chnls in a straight horizontal line with cntr chnl. The cntr chnl shares heigth within 1" with the frnt chnls. (32"above floor) I then set the RTi F/Xi A6's (thanks Leroyjr1
) surrounds at 16" above the front stage (so 48"above floor)
hope this helps.
Merry Christmas' USA!
Matt:biggrin:
Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears... -
MJ, First off, welcome to club polk! Feel free to introduce yourself on the welcome page of the forum. I've attached the manual for your speakers here so you can place them in accordance to your arrangement. There is a chart on the 3rd page of the manual that will help you use the ideal placement.design is where science and art break even.
i like my surround speakers high on the back wall. i have mine about a foot from the ceiling.. works great. esp since your speakers are bi/di pole. so I recommend you start with them high, then adjust to your liking. there is not wrong or right placement.. each room/house is different.PolkFest 2012, who's going>?
thanks for the help, i understand the placement of the speakers relative to where u sit in the room, but my concern is the height which i could not find in the manual, i am going to pre-wire the walls before i hang the drywall, so i would like to have an idea where to bring the wire out of the wall into a face plate
