Cherry Subwoofer that matches LSI cherry?
grimmace19
Well as a lot of you have seen I am moving into a new home at the end of next month and after a lot of thinking about the theater room it seems that my dual subs may need to go. This thought in my head is a bit bitter sweet considering my klipsch sub-12s aren't the greatest but do hit hard. And in the same regard I will go from 2 subs down to 1. With that being said if I do go down to only one woofer I need something pretty beefy that I wont feel like I'm missing something. But, my other major concern is trying to find one that has the same finish as my cherry LSI's. I think the old psw1000 had a matching finish but is long gone and hard to find (if I would even want one).
Does anyone have a cherry finished velodyne? Online it looks like the wood finishes look like LSI's but at the same time my 15's and 9's don't even match!
Any input is great... maybe I will just save for 15 years and buy a JL in gloss and call it good.
Post edited by grimmace19 on
your 15's and 9's done match most likely because they changed the finishes mid stream on the LSi (some like the old, some the new....I lean toward the new but like both)
DIY perhaps? with cherry, it seems no one ever uses the same shade........ever.Living Room 2 Channel -
Upstairs 2 Channel Rig -
