Furnace air filters
Strong Bad
Strong Bad Posts: 4,278
edited July 2011 in The Clubhouse
Just curious to see which air filters you folks use out there.
When I bought my home 2 + years ago, the inspector told me that I can get away with using the cheapy $3-$4 monthly filter and to not waste my money on the expensive ones. After looking at what the previous owners were using, I couldn't see how something so cheap could trap all the dust in the air. I decided to start using these and haven't stopped changing it every three months...
3M Filtrete Maximum Allergen filter
It pays to spend the $20 every three months. Hell, it's the air you breathe, so don't go cheap!
No excuses!
Post edited by Strong Bad on
  • Knucklehead
    Knucklehead Posts: 3,602
    edited December 2010
    I use an electrostatic air filter, I wash it out with the hose about every 3 months, Ive noticed a lot less dust in the house as well.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • greyford1979
    greyford1979 Posts: 749
    Yep this is what I use as well. The gold enforcer 94. Although you have to be careful because not as much air flows through it, and have been known to cause problems with some furnaces like shutting down the furnace. Also have to make sure they are cleaned properly and dry when you reinstall it. These ones come with a lifetime warranty.
    http://acfilter.com/onlinestore/filterse/
    I love animals, they're delicious!
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Use one myself, over 6 years old now dirty I wash it with the hose.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    tonyb Posts: 33,068
    I used to use the top brands, to keep dust down and all that,untill I had to get my furnace cleaned. They recommend the cheaper ones because they let more air flow, and the furnace burns more efficiently, saving you money on gas and repairs.
  • bruss
    bruss Posts: 1,039
    tonyb wrote: »
    I was recommended this as well and its def true. They are cheap and i change it oncce a month
  • WilliamM2
    WilliamM2 Posts: 4,806
    I use these 20"x25"4" filters, not much choice, thinner filters won't stay in the box. Only need replacement once a year, about $20 at Menards.
    http://www.amazon.com/BestAir-52025-Whole-House-Filter/dp/B0006OQCTS
  • steveinaz
    steveinaz Posts: 19,545
    I like the Arm & Hammer type.
  • Knucklehead
    I think the ones that allow better airflow may be ok for oil or gas furnaces, In this psrt of the Country we have forced air heating systems so I guess its not that big of a deal.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    treitz3 Posts: 19,959
    I've had two in the house for about 4-5 years now. Not one speck of dust in the furnace or vents. Just be sure to clean them thoroughly and as often as you would replace a normal filter and you will not experience any issues.
    Besides, I hate spending money on things I have to throw away just to turn around and repurchase.
  • Midnite Mick
    Midnite Mick Posts: 1,591
    I can't use the expensive allergen trapping ones. I have to use the cheap ones that allow more air flow. I have a little electric forced air furnace that gets too hot and causes the elements to constantly go on and off if I don't have maximum air flow.
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • FTGV
    FTGV Posts: 3,650
    Interesting I have an electric furnace and use the premium filters linked to by the OP.I have not noticed any overheating issues .But if it is making it work harder and since the cost of hydro is skyrocketing in Ont.I might switch to the cheapies.
  • Joe08867
    Joe08867 Posts: 3,919
    steveinaz wrote: »
    I use the Arm & Hammer ones as well. Work great cut back on dust and Allergens in the house.
  • madmax
    madmax Posts: 12,434
    I use the cheapies.
    Vinyl, the final frontier...
  • disneyjoe7
    My recommendation http://www.boair.com
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • dorokusai
    dorokusai Posts: 25,576
    I'm a Filtrete user and don't change it every month, that's silly. I'm on a 3 month rotation like John. I don't like the electrostatic, wash 'em types...just preference.
  • Joe08867
    edited July 2011
    Really Coltleader? You searched the web for air filters and it brought you to Polk Audio?
    Reported as spam
  • timlitton
    timlitton Posts: 289
    edited July 2011
    There's a trade-off between Indoor Air Quality (IAQ) and airflow. EPA Studies have shown the air inside your home can be 2-5x's more polluted than outdoor air due to the natural breakdown of your home's materials over time. This is compounded by tighter and tighter home envelopes.
    But, as I said, some high efficiency filters negatively affect airflow and cost you more in operation costs.
    Slowly emerging from the 90's
    Fronts: Polk LSi15's
    Center: Polk CS350ls
    Pre: Sony STRDA555ES
    Amp: Rotel RMB-1075
    Sub: Velodyne SPL-1000
    TV: 46" Sharp Aquos LCD
    Dust magnet: Sony PS3
  • gdb
    gdb Posts: 6,012
    edited July 2011
    The simple solution is to get out your sheet metal tools and increase the filter area in your return duct. If you're good, you can make channels in a vee shape V, and put two filters where there was only one before.:wink: Don't %$#@&^% cut yourself.:frown:
  • BIZILL
    BIZILL Posts: 5,432
    edited July 2011
    no more of the pleated paper-type media. too restrictive and caused icing issues due to airflow on my ac unit. was recommended the cheap ones which are less restrictive and i'm never going back. big difference in air velocity from the registers as well.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
    tonyb Posts: 33,068
    edited July 2011
    The previous owner of my house, and myself, use the same guy for regular maitenance on the furnace and air conditioner. 38 years later, I still have the original of both. Mind you by todays standards,still not as efficient as newer models. His advice to both of use were to not use anything that restricts air flow unless you like replacing that furnace every 7 or 8 years. The designs are build on x amount of air flow and when that doesn't happen by way of a filter restricting it, you get heat built up and possibly a cracked heat exchanger. Now, as he would say, what costs more, alittle more dusting, or a new furnace, the choice is yours.
    My guy is an old self employeed Air force dude, been in heating and air while in the armed forces and ever since. What he claims some companies do as marketing borders criminal. No engineer in their right mind would tell someone to restrict air flow on a furnace, then again, there are no engineers doing the marketing. I think 38 years of servicing my heat and air, still original, still working great, is a good testimony to his advice. He also schooled me on chimney length and high efficiency furnaces. Most high efficient furnaces can't push the excess heat up a long chimney and need a direct style vent through a wall. A common mistake he see's all the time without nearly a mention from the company who installed it for a homeowner.
  • dorokusai
    edited July 2011
    I'll do a check and go back to an older filter to see if airflow and conditions change. I believe the conversation here has at least made me aware of some other things that I should consider.
  • [Deleted User]
    [Deleted User] Posts: 1,225
    edited July 2011
    Due to recent problems with allergies, I want to try the Filtrete Ultra Allergen (purple) filters. Problem is the size I need (14 X 30) isn't carried, well basically anywhere. I need to get them special order and I need to buy a case of six for roughly $100 bucks plus shipping. Still debating. :cool:
  • dorokusai
    edited July 2011
    That's what I use now and have seen no issues with my system but as aforementioned, will do a month with an old one to see what happens.
    tonyb Posts: 33,068
    edited July 2011
    nap wrote: »
    You maybe better off with a whole house air cleaner, more expensive initially, but may provide better air filtration for you.
    Don't mean to change anyones thoughts on what works for them. Just my own experiences is all. When you break down the technology, from old furnaces to newer ones, you have to follow what they were engineered to do, and the upkeep that allows a certain design to work as it should.
    That said, my units being as old as they are, need updating,not because they don't work, because the design is not as efficient as todays and I'd probably save some coin in the long run. My guy tells me he could keep them operational for another 5-8 years, but I'd be wasting money keeping an inefficient furnace. I figure 2 more years to make it to the 40 yr mark and cash them in. My problem is where the furnace is located, I don't have an area to go direct out the wall, so it has to go up a chimney thats almost 30 feet. That limits the amount of efficiency I can have in a furnace. Was told I could get away with about a 90% efficient one, lots better than what I have now but definately not the most efficient. Such is life.
  • kefranklin
    kefranklin Posts: 141
    edited July 2011
    As a HVAC tech, I have learned that if your unit freezes on cooling or shuts down on heating because you use good filters it is not the fault of the filter. This happens because most systems have filters or return plenums that are too small. The only way that using the non-pleated filters will help anything is if you are not willing to fix the real problem, which is lack of return airflow. If your unit breathes as it should, any 1 inch thick filter will not cause issues.
  • BlueFox
    BlueFox Posts: 15,251
    edited July 2011
    nap wrote: »
    Just ordered a 14x30x1 case of 12 last night from Amazon affiliate for $50, free shipping.
    http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dtools&field-keywords=14x30x1+Heavy+Duty+PolyStrand+Furnace+&x=19&y=17
    Never mind. Missed the part about special allergies.
  • gdb
    gdb Posts: 6,012
    edited July 2011
    nap wrote: »
    IMO, you'd be better served by having your return duct re-worked to accept a large (stock size) filter. More filter area + cheaper filters + increased air flow + no more special orders.:smile:
  • SDA1C
    SDA1C Posts: 2,072
    edited July 2011
    tonyb wrote: »
    Exactly my thoughts and the direction we went. Put the cheapy in your furnace to catch the big stuff. To clean your air get an air purifier. It seems logical to me to let the heater, heat and let the purifier, pure lol.
    Too much **** to list....
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited July 2011
    K&N here.
    Actually Filtrete, and I should probably check it now.
  • polkatese
    polkatese Posts: 6,767
    edited July 2011
    nap wrote: »
    I have the same size as yours and been ordering them from these folks for the past 10 years:
    http://www.filters-now.com/products/mmb.html#MB14X30
    free shipping for order more than $100 (I usually ordered in quantity of 12)
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
