SRS 1.2TL with Blackhole 5 Damper
PolkMaster1
PolkMaster1 Posts: 847
edited April 2011 in Vintage Speakers
I am starting my damper project on my SDA-SRS 1.2TL Speakers. These speakers went through some extensive modifications -
Soniccap Upgrades, RD0198TL Tweeters, Dynamat on the driver rings, and Mortite. I have a few more projects I will be performing on these speakers in the next year. Right now, I will be focusing on applying Blackhole 5 Damper.
I purchased three sheets of Blackhole 5 Dampers from Soniccraft. This I anticipate using two sheets, but I purchase an extra sheet in case more is needed. The Blackhole 5 Damper is 24 inches wide by 27 inches in height and 1.375 inches depth. Other items you will need for this project is steel wool, a vaccuum cleaner, scissors, pen or pencil, measuring tape, and a screwdriver or drill. Most of the items that are needed are fairly obvious. The steel wool and vaccuum is needed to clean the surface that the BH5 will be applied to and to clean up the debris that your speakers have accumilated and will accumilate with the cleaning process. You can pick up steel wool at the Home Depot for $3 or so.
I picked up a Grade 2 wool pad since I dont anticipate much surface debrit.
Statistics show that 98% of us will die at some point in our lifetime.
The other 2% will work for WalMart.
Post edited by PolkMaster1 on
  • PolkMaster1
    edited December 2010
    I started the project by removing the passive radiator, since this is where the BH5 will be going through, then the drivers. I left the tweeters in place since I dont believe it will be needed to be removed to complete this project. Here is the near-skeleton view of the SRS 1.2TL.
    Notice that the original damper is applied at the mid-drivers. I will be applying the BH5 damper only in this area as it is recommended to apply it to this area only by Polk Audio. I may remove the tweeters if they get in the way when applying the BH5.
    Toolfan66 Posts: 18,074
    Just gut them it don't take much more time and you won't have to worry about breaking anything..
  • PolkMaster1
    Here is the BH5 - in the flesh. This is it for now. More to come tomorrow.
  • joeparaski
    joeparaski Posts: 1,865
    I'm not sure so I gotta ask.......what is BH5 and what does it do?
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • PolkMaster1
    joeparaski wrote: »
    Joe
    Its a self adhesive damper that replaces the polyfill in your speakers.
  • PolkMaster1
    I made my first set of BH5 for the left speaker. It took me 4 hours to complete it. If all works well, the next set for the right speaker should take less time. Here is what it looks like.
    I applied the BH5 only to the midrange drivers and tweeter area. No BH5 was applied to the PR area.
    I did not pull off the back adhesive for now. This allows me to take out the BH5 if I want to experiment or if I want to remove it in case I am not happy with the results. If I like the results, I will remove the back adhesive for a permanent fixture.
    Thats perfect I would not do anymore then that..
  • PolkMaster1
    Here is what the polyfill looks like - in the nude.
  • PolkMaster1
    And here are the drivers... all alone and distant from its home....
  • PolkMaster1
    Its time to send the drivers and PR back "home" and test the sound. I need to make some final touches with the BH5. If this sounds good, those final touches will be complete.
    I would still use the polyfill buy thats just me.. I would try it with and without..
  • PolkMaster1
    I forgot to mention a few additional items you will need to complete this project, so I will sumarize it here -
    steel wool
    a vaccuum cleaner
    scissors
    pen or pencil and paper - to record the measurements of each cut you make on the BH5 for the first speaker. It will help make the cutouts for the second speaker go more qickly.
    A Permanent Marker - I find this helpful to mark the measurements of the larger panels you will be cutting on the back of the BH5.
    a measuring tape
    A flashlight
    A utility knife
    A dust mask - in case when working inside the cabinet, the wood may give off a unique scent that some may find overwhelming to take in (like me).
    You may find other items helpful to complete this project. This list should
  • PolkMaster1
    I probably wont do this. This may overdampen and take life out of the sound. I may change my mind later on, because I will have to go back into the cabinet at least once more.
    BTW - It is recommended to keep the BH5 at least 2 inches away from the drivers. In case anyone is having thoughts of putting BH5 on the back of the driver side of the cabinet, dont do it - it is not recommended. It is one of those cases where more is not necessarily better.
    I take this the advice of the audio gods who have helped out with my endeavor for achieving the best sound possible from these speakers. I dare not challenge the audio gods wisdom.
    VR3 Posts: 29,444
    I have never used BH5 but the idea behind Soundbarrier and No rez is it takes no internal space what so ever - you still use all polyfill that was originally in the speakers
    Just future reference
    Yep I have the polyfill in my 1C's with the BH5..
  • PolkMaster1
    OK, I tried out the BH5 in my left channel speaker for a couple of hours. I figure to share the experience with fellow polkies on what my initial reaction is. My first reaction is that thi stuff works too well. It dampend so much that I did not hear anything coming from the speaker. The effect was silently deafaning. I went checking around to see what was going on and I think I found the culprit.
  • PolkMaster1
    Once I "fixed" the problem, another problem surfaced - strangely enough - I heard unwanted sounds coming from the GF. Things like "stupid" and "idiot" came in the same sentance. If I did not know better, I could swear that those sounds were references twords me. Thankfully, I reminded her that I have enough BH5 to "dampen" these unwanted sounds. That statement seemed to be effective in silence from the GF.
  • PolkMaster1
    Now it was time to do some critical listening. At first, I was pleasently surprised. I heard more midrange and trebble with the polyfill being replaced. However, I felt something was... missing. The sound felt lighter, without impact, and a lack of bass coming from the left side of the speaker. I was tempted to remove the BH5 and put back in the polyfill. I removed the grille and discovered what was missing. Only a trained eye can discover this small detail on what is missing. I leave it to you to see if you can find it.
  • PolkMaster1
    OK, it really wasn't missing. I purposely took this shot before putting everything together to give everyone a good laugh.
  • PolkMaster1
    Before I get into what it sounds like, I will start with where the BH5 was applied - it was applied only to the back wall, starting from the midrange and tweeter area, working my way up to the top of the speaker. I did not apply the BH5 to the top pannel or the sides. This may change in the future. If I apply any damping to the top pannel or sides, I may use Sonic Barrier. I am not certian yet in which direction I will go. I did not try using the BH5 with polyfill as some people have with their speakers. This may change in the future.
    OK, so, what does it sound like? Well, lets say that once I took care of a couple of "problems", I was able to take it for a test drive for a couple of hours.
    My initial thoughts is that the sound is very pleasing. The sound on the left speaker with BH5 applied was more lively. The mids seemed to be a bit more stronger, and tweeters were brighter comparing it to the right side. I did not notice any stronger bass or an expanded SDA presence, but my ears may need to adjust. (Hint - Bridezillas and the We channel does not make an effective test platform for an SDA speaker. This was not done out of will.) I will give more feedback on this later in the week when the We channel has been effectively blocked.
    To sum it up, I really like the results I hear so far. I am looking forward to applying it to the right side, which I hope to get to it later in the week, or by the new year. After applying it to the right side and doing some critical listening, I will give my recommendations - yea or nay.
  • PolkMaster1
    Update -
    I have now used the Blackhole damper in the left speaker and the standard polyfill in the right speaker for a little over a week now. I found out that the right speaker with the polyfill which had less trebble output was due to the topmost tweeter not functioning. I removed the tweeter from the cabinet and the wiring from the crossover. I tested the tweeter and wiring for continuity. All checked out appropriately. I proceeded to reseat the tweeter and connections. The tweeter was restored and trebble balance was even.
  • PolkMaster1
    Once trebble balance was restored, I wanted to take on the challenge that was posed by Tool for Life - to try polyfill with the BH5 damper. My first thought about this idea was that the speaker would be completely dead and lifeless. The thought of this was discouraging. However, I rethought the idea since the BH5 is applied only to the back wall (no padding on the sides), I became concerned with the lack of polyfill would have an effect on the bass - it may not be as effective as it would be with the polyfill in place. I do sense the bass slightly favoring the speaker with polyfill over just the BH5. I am not sure if my thoughts are real, or if it is all in my head.
    Despite my thoughts, I proceeded to fill the right speaker with BH5 and add the polyfill as of last night. So now, both speakers have BH5. Only the right speaker has polyfill added. The polyfill and BH5 is added only to the midrange area. No fill is in the PR area, and should be avoided at all costs!!! If anyone is thinking of taking this project, remember not to apply any fillers in the PR area. Keep it in the midrange area and above!!!
    So with the limited sampling for the past couple of hours, I do not sense any difference in the midrange and trebble areas. But I do sense that the right speaker (filled with BH5 and polyfill) has a slight edge in bass output. I still need to perform more sampling between the speakers and will update my progress.
    I am considering cutting the polyfill taken from the left speaker to cover just enough of the first set of midrange speakers over the PR area in an attepmt to even the bass without covering the entire midrange area.
  • Outfitter03
    Outfitter03 Posts: 563
    A couple of questions for the OP or anyone else who may know the answers.
    Is the adhesive on the Black Hole 5 better than on the Sonic Barrier or does it also require additional glue or mechanical attachment to remain in place?
    Are the two small pieces of polyfill shown in Post #9 all the polyfill that is placed in the 1.2TL? This would not seem to provide much damping.
    http://www.bobgolds.com/AbsorptionCoefficients.htm
    Why would you not want to have polyfill behind the tweeters? Do the magnets/base prevent the high frequencies from going into the speaker enclosure?
    Very nice thread PolkMaster1 and thanks for sharing your progress. Those are incredible looking speakers!
  • PolkMaster1
    Thanks Outfitter03.
    I will answer what I can.
    Although I have not pulled off the adhesive covering yet for permanent fixture, the Blackhole 5 does have its own adhesive and it feels pretty good. For best adhesive results, lightly scouer the areas where you would place the BH5.
    I have not used Sonic Barrier, so I cannot make comparisons. ToolForLife may know the answer to this.
    The polyfill picture can be deceiving - they are not small at all. The two peices of polyfill covers the entire midrange area. Each peice is 13 inches wide by 32 inches in height - unfolded. When you insert them into the SRS, you will fold them. The folded measurement is ~7 inches by 32 inches.
    Your assumption is correct. Some additional info:
    The polyfill can reach the tweeter area quite easly, but because the tweeters are sealed (unlike a driver which has a gasket) and because of the internal bracing inside the cabinet, there is no need to emphasize polyfill in the tweeter area. The bracing does keep the polyfill seperated in their own areas, but the bracing does not impede on the polyfill from forming around the tweeters.
    I used the BH5 behind the entire surface of the midrange area, so the wall behind the tweeter area is also covered. Someone can chime in if they want to add any input to this question.
    Thanks again. I hope to share more with other projects I have for this speaker.
  • dcoil
    dcoil Posts: 153
    Just when I think I've got all the mods done to my Polkies, someone comes up with another one!! Cut it out already ;)
    Seriously, thanks for the write-up!
    SDA SRS modded: X’ovrd, de-polyed, inductorized, interconnectorized, re-posted, dynamited, RDO’d, spiked, gasketed, ringed (Larry's), and grill cloth blinged! Done this on my own? Not a chance. Thanks to Raife and all who forged easy to follow upgrades. At least a 100% improvement in sound and my personal listening pleasure! :cheesygrin:Pass XP-10 preamp, Parasound A21 amp, Pioneer Elite DV-58AV (Ric Shultz modded), Audioquest Sky IC's, No longer need my Sunfire sub after mods...
  • PolkMaster1
    dcoil wrote: »
    Your most welcome.
    I should mention two things:
    1. that ToolForLife had done this not to long ago in the past and wrote a thread about it. I am not the first to post about BH5 in a Polk speaker. I do not know if other threads exist about BH5 in their PA Speakers.
    Tool was not satisfied with his results. I spoke with various people regarding the BH5 (including Tool) on where it would be best to apply it. I took the project in a slightly different direction and got satisfactory results.
    2. After visiting the Sonic Craft website many times and reading about BH5 on their website, I was leaning in this direction on if I should apply it to my speakers for a couple of months before taking on this project (a sale also helps!). I only found out about Tools writeup after I made my decission to take on the project and his input helped point me in the right direction on where and where not to apply the BH5.
    If you decide to take on this project and follow the instructions I laid out, keep in mind that most of your time will be spent measuring and cutting - measuring 60%, cutting 40% on the first speaker. Then 40% measuring, 60% cutting on the second speaker - assuming you recorded your measurements on the first speaker. You may need to take secondary measurements when applying it on the second speaker - some of the bracing is opposite for each speaker.
  • Face
    Face Posts: 14,340
    It's not that difficult to cut correctly.
    I use a straight edge and use it as a guide for my initial score with a razor. Then cut the rest of the way through with a pair of sheers, carpet scissors, etc...
  • PolkMaster1
    This stuff is thick, so cutting is a challenge, even with a utility knife and really good scissors. I dont have carpet scissors, so I cannot say how that will work on BH5.
    And the backing makes it difficult for permanent markers, pens, and pencils to make a solid permanent mark. I find pencil is the best when I make lines, but you do have to go over the lines several times to make the mark stand out. Pen is very difficult to use on the backing, and permanent marker looks like a water marker on this backing.
  • Face
    Face Posts: 14,340
  • PolkMaster1
    Face -
    I read somewhere that they used a saw to cut through the BH5 with good results. Cant remember where I read it. Again, I have not tried this, nor do I have access to carpentry items - most of us apartment dwellers do not have such things lying around, unless we do carpentry for a living. I am not one of them.
