Looking for speakers....
Hi friends ,
I am searching for PC speakers. My previous PC speakers have been damaged. So that's why I am looking for new one. Sound quality should be awesome, heavy bass required, wire should be long. No compromise with the sound quality of the speakers. So please recommend me the website where I can check out and purchase the latest and best quality speakers.
Post edited by peter4 on
reported before you could even create your next account.
Dynamic magnet shielded, ehh? WTF is that?
reported. :rolleyes:The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Cloaking device. Romulan technology. Very dangerous.
WAAAAA !!!:biggrin:
Obviously developed in a secret lab over at AH.
lsi 9's -
WELCOME TO CLUB POLK!!
Rti-A9s would certainly give you BIG sound...but you'd need room and some REAL power for them. You would use 'these' as PC speakers? I suppose you could.
I'd go with the smaller Rti-A1s and get a Polk Micropro 1000 to fill in the low end. Take up less space. If you want bass in a PC system...it seems to me you need a SUB.
I would say Cnh has the best option for a traditional computer set up, can't tell if the OP was even looking for a component system or specific computer speakers.
that said, the component route will get the best sound the OP is looking for, but the bookshelves (over going the tower route )will fit better with the traditional computer set up (more near field)
the rtia1's and sub listed will be great for that, but you will need amplification of course.
the big towers Xcapri noted won't really fit that model, as you will have to be further away from the speaker to really get the full effect right.
It will depend on how the OP will listen to these.Living Room 2 Channel -
Upstairs 2 Channel Rig -
