Can one use a "normal" amp on the sub output
thor098
thor098 Posts: 38
I'm starting to build a home theater system. I bought a Denon 3311ci and I have an older Adcom 545 amp left over from building my two channel system. Can I use it to power two passive subs from the LFE sub ports. Will it recognize the LFE signal? Will it hurt anything?
2 CH
Parasound 2100 preamp
Polk Lsi15s
powered by a
Parasound HCA 1500a
2 Passive JBL 10" Subs
powered by a second
Parasound HCA 1500a
HT
Denon 3311-CI
Polk Lsi15 Fronts
Polk LsiC Center
Polk Lsi7 Surrounds
2 Passive Polk 10" Subs
powered by ADCOM 545
Post edited by thor098 on
    treitz3 Posts: 20,069
    edited December 2010
    Yes, no.
  • ohskigod
    ohskigod Posts: 6,505
    I've done that.........as long as the amp works and your sub is passive......your good to go if you hook it up right. do NOT hook both channels to one sub (or driver voice coil) very bad for the amp.
    if you see only one input, one channel of the amp goes to it (or bridge amp if the sub is 8 ohms perhaps)
    they do make Dual Voice coil subs so you can hook 2 channels to it.
    it's fun to experiment, but my experience led to plate amps made for sub service being the best route, but again, trying can't hurt
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
