Turntable Purchase Help
SolidSqual
Hey Guys,
I have about $2,100 to $2,800 spend on a new Turntable. My only experience previously with TTs is a Pro-ject RM5 SE which I felt produced superb sound when paired with a Blue Point No.2 Cartridge and Jolida JD9A Phono pre. Now that I got my Prism Orpheus, I want to get a TT that can really take advantage of this cutting edge phono section. I've been looking at VPI, but the mixing and matching is a little intimidating. Are there any other brands that will best my RM5SE, or should I just stick with Pro-ject? I like the fact that the Pro-ject gear comes with cartridge installed. Any help would be much appreciated.
Regards,
Mike
Regards,
Mike
Post edited by SolidSqual on
here you go Mike...
http://www.audiogon.com/cgi-bin/cls.pl?anlgtabl&1296759923&/Vpi-Scoutmaster-JMW-9The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I feel weird buying a used TT. TTs are such precise instruments that I can't hep but want a warranty. Besides, F1Nut said not to long ago that buying a used TT is normally not a very good idea. He's given me audio advice in the past and it is usually spot on. I'm afraid if I buy used, I'll only prove him right.
The new VPI Classic is one of the highest rated tables in it's price range going. I think it would work wonderfully with almost any phono stage. If I could afford one I'd be all over it.
http://www.elusivedisc.com/prodinfo.asp?number=HW-CLS10W
You may be able to find one cheaper. Tons of upgradablility with this table as well.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
I think the two best TT deals under $3K are the Marantz TT-15 and the VPI Classic. Both are simply great tables for the money.
The Marantz can be found new for $1400. Cart and everything is included.
I love mine.Speakers: SDA-1C (most all the goodies)
