TTWeights outer ring clamp
doctorcilantro
After finally getting my turntable back online, I found I can't really make enough adjustments to allow the use of a TTWeights outer ring clamp I bought. It is the nickel-plated copper version which I don't think Larry is going to make in any weight much longer due to the cost.
It would be perfect for lightweight tables but should also help dampen on heavier platters too.
It listed for $ 459.00 (because of the nickel-plating and extra damper 'bumps') I'll let it go with some fingerprints, the velevet bag, and plastic mounting/spacer tool for $320 shipped CONUS.
Pics comin'.
Here is description of the 600g model which is same except for weight.
Pics comin'.
Material and Engineering Summary:
1. Nickel Plated Bright Silver Diamond Machined Finish
2. NEW: 5 Special Tuned Dome Shaped Inserts tune the Outer Ring
3. 99.99% Pure Copper/Stress Relieved and Heat Treated
4. The surface is cleaned, chemically etched and Nickel Plated
5. Will never oxidize and does not require polishing
6. 600 grams/1.322 lbs
7. Dimensions: 13.500 Diameter x .125 thick.
8. Inner counter bored diameter 11.900 x .110 deep, the record is inset.
9. Our unique centering tool is included for easy installation, 5 second install time
Engineered to Perform
The raw blanks are machined from COPPER the most musical and stable of materials, with super precision machining of the outer lip and designed to self locate on the LPs outer edge and a special centering disk is included for centering on smaller outside diameter and other problematic records.
It is very simple, you can build a great performing turntable but the record is the source of what you will hear, it must be coupled for true to life and realistic playback.
Benefits
The outer ring will flatten warped records and provide an enormous improvement in record control and sound quality from proper record to platter coupling. The record no longer resonates and subsequently the dynamic range and accuracy and depth of soundstage is improved dramatically.
This outer ring will fit all records and improve the playback quality of all records new and old.
Stylus Clearance
The top surface of the ring is less than .010 higher than the LP surface providing excellent clearance for the Stylus on the entry groove of the record with manual and automatic turntables.
High Density, Low Mass COPPER, Superb Dampening Capability
The Outer Ring is machined from solid COPPER with a specific weight 3 times higher than stainless steel. Stainless rings will resonate (ping/ring) while copper is very dense on a molecular level and does not share these problems. You may ask why the Outer Rings have not been produced in COPPER.
The answer is simple, COPPER 1/8 thick x 13 plus inches and extremely thin walled areas make the machining extremely difficult. To make a ring this size, perfectly flat and concentric, we use advanced water cutting CNCs and MULTI AXIS CNC Lathes and each ring is produced by a senior Aerospace Machinist. The rings are flat and concentric within .001 maximum, average > .001 over the entire ring, not an easy task.
The Sound
The outer ring will provide dramatic improvements to the records imaging and sound staging. The Outer Ring can be used alone, but the use of a TTSuperClamp or other center weight product is highly recommended. The absolute peak performance will be gained when there is no free play or movement from the vinyl itself. The Outer ring and clamp essentially locate the vinyl directly to the mat, significantly reducing distortion even with worn record grooves. THE TTOuter Ring will reduce and remove the warp in most warped records except for the most extreme. If the record is more than 3/8 of an inch warp the ring will flatten most of the warp but they may still be unplayable. Caution is advised.
The TTOuter Ring reducing high frequency noise caused by microscopic vibration that causes the stylus to hear sounds that are not there, this causes listening fatigue. The true high frequencies can be extracted from the vinyl essentially cleaning up the distortion caused by a vibrating the record groove. Play only what is there in the groove. The TTOuter Ring provides smooth and accurate sound across the listening spectrum. The quiet passages are beautiful, less background noise, less tracking and VTA errors create awesome dynamics.
TTCentering Disk Included
Note: TTOuter Ring will self locate on many albums and the Disk does not always have to be used.
This device is designed to locate the TTOuter Ring Concentric to the Platter centerline with 10 thousands of an inch.
Provides a storage platform for the TTOuter Ring when not in use
Simple and very effective with problematic albums, not all albums are made equally!!
Technical Specifications TTOuter Stabilizing Ring:
Each Outer Ring Package:
· 1 COPPER Universal Fit Outer Stabilizing Ring
· 1 Centering Disk to be used as required
When the Outer Ring is located on the record it sits deeper than the thickness of the LP thus the maximum platter or mat diameter is 11.9 inches. If the TTMicroMat (not included) the ring can be mounted on any size platter.
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
Post edited by doctorcilantro on
For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center -
I found the info for the 290g model:A ring for LIGHT TABLES !!!
The new TTOuter Ring is machined from solid COPPER providing ground breaking vinyl performance. The source of the Music is the VINYL and everything else is dictated by the accuracy of the information extracted from the vinyl.
The raw blanks are machined from COPPER the most musical and stable of materials, with super precision machining of the outer lip and designed to self locate on the LP’s outer edge and a special centering disk is included for centering on smaller outside diameter and other problematic records.
Stylus Clearance
The Outer Ring is machined from solid COPPER with a specific weight 3 times higher than stainless steel. Stainless rings will resonate (ping/ring) while copper is very dense on a molecular level and does not share these problems. You may ask why the Outer Rings have not yet been produced in COPPER.
The answer is simple, COPPER 1/8 thick x 12.75 inches and extremely thin walled areas make the machining extremely difficult. To make a ring this size, perfectly flat and concentric, we use advanced water cutting CNC’s and MULTI AXIS CNC Lathes and each ring is produced by a senior Aerospace Machinist. The rings are flat and concentric within .001 maximum, average > .001 over the entire ring, not an easy task.
The Sound
The TTOuter Ring reducing high frequency noise caused by microscopic vibration that causes the stylus to “hear” sounds that are not there, this causes listening fatigue. The true high frequencies can be extracted from the vinyl essentially cleaning up the distortion caused by a vibrating in the record groove. Play only what is there in the groove. The TTOuter Ring provides smooth and accurate sound across the listening spectrum. The quiet passages are beautiful, less background noise, less tracking and VTA errors create awesome dynamics.
Includes :
Dimensions : 12.75 Diameter x .125 thick.Inner counter bored diameter 11.900 x .110 deep, the record is inset. The Tapered locating surface will self center larger diameter records. Some LP’s are smaller and require the use of the centering disk.When the Outer Ring is located on the record it sits deeper than the thickness of the LP thus the maximum platter or mat diameter is 11.9 inches. If the TTMicroPlatter (not included) the ring can be mounted on any size platter.
Weight : 290 Grams (.639lbs)
Limitations : Designed for light suspended tables. Cannot be used on oversize platters bigger than 11.945 inches unless you install a TTMicroPlatter or a .080 minimum mat thickness and a diameter of less than 11.900 inchesFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
pm Sentintegrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
Doc r - pm sentFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
Back up for sale!For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
bump 300 shipped via Paypal GiftFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
Is this still available for sale? PM sent.Statistics show that 98% of us will die at some point in our lifetime.
The other 2% will work for WalMart. -
sorry just soldFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
