Moving Polk speakers
mwelna
mwelna Posts: 24
edited December 2010 in Vintage Speakers
Hi,
I'm sure there is info on this somewhere but i can't find it.
I will hopefully be going to pick up a pair of RTA-15TL's this evening.
I've purchased polks that have been shipped in the past and had their drivers "frozen" during shipping.
Does anyone have any thoughts about transporting polk speakers by car? I.E. would it be safer with them on their sides or backs?
I would think on their backs so the suspensions can work as designed?
Opinions or thoughts please?
Mark
Post edited by mwelna on
    Toolfan66 Posts: 17,338
    BACKS!!!! With padding underneath (moving blankets ect..)
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • mwelna
    mwelna Posts: 24
    Excellent! Thanks. That's what i suspected. I suppose i'll need to bring some 2' x 4's to get the backs off the floor as to not damage the passive woofers.
  • Vette C6.r
    Vette C6.r Posts: 1,560
    I would just move them on the side since the 15's have drivers front and back.
    That's how I moved mine. No worries at all.
  • ben62670
    ben62670 Posts: 15,969
    Backs. It is very easy to take out the rear passive.
    Ben
  • mwelna
    mwelna Posts: 24
    thanks. great idea. i'm paranoid about magnet shift with all of those beautiful drivers on their sides.
    I'll remove the rear passive and trasport them on the backs swaddled in blankets!
    Mark
  • brgman
    brgman Posts: 2,859
    mwelna wrote: »
    Mark
    Thta's exactly how i moved mine and in the back of a truck for several miles had no worries,no problems.
    I’M OFFENDED!!!!
  • mwelna
    mwelna Posts: 24
    Thanks guys. I've always wanted 15tl's. I currently have SDA CRS's and have owned two pairs of 8tl's in the past. But i've always had a thing for the real wood veneer and those black lexan tops. Wish me luck!
  • gdb
    gdb Posts: 6,012
    One quick thought.... I would avoid any large or sudden temperature changes with them if possible. Rapid expansion and contraction and all that stuff!:cool:
  • mwelna
    mwelna Posts: 24
    Ha!...........I"m in Minnesota. We are actually getting a break right now. It'll be about 16 degrees F when i pick them up!
    F1nut Posts: 50,761
    You are over thinking this. The magnets are not going to shift from simply driving down the road. Dropping the speaker might, but not always. Removing one or more drivers/PR's will allow the other drivers/PR's to actually move more than if you leave all of them in the cabinet.
  • Vette C6.r
    Thanks F1
  • civilian
    civilian Posts: 357
    Assuming you are moving them in a passenger car, truck or SUV, you are more likely to damage them loading or unloading. Of course if you fly over speed bumps and curbs all bets are off. Delivery trucks suspension is not designed for comfort.
    ________________
    2 Channel-Denon AVR-4520/SDA 2.3TL's
    5.1-Denon AVR-4500h/RT3000P's/CS1000P/RT2000P's/
  • gdb
    gdb Posts: 6,012
    Once home......do the JB Weld process to insure that the magnets stay put. Magnets have come loose while the speakers were being played and........just sitting idle too!:eek:
    F1nut Posts: 50,761
    What a crock.
  • dorokusai
    dorokusai Posts: 25,577
    I bounced a pair of SDA SRS 2B's in the back of my truck for 3 weeks, because I paid zero for them, and they were fine. I literally would speed up for speedbumps and anything that would potentially harm them...potholes, larger speedbumps, tight turns, etc etc...you get the picture. Oh well, I guess everyone has a different experience. I ended up selling them on Audiogon, local and the buyer loves them....LOVES them with nary a magnet issue or complaint about performance. I checked them out before hand, don't worry I just think it's amusing overall.
    Weird huh?
  • gdb
    gdb Posts: 6,012
    What a crock.
    Yes,yes you are! Sweetcheeks:tongue: When the glue finally gives up the ghost, there's a VERY strong pull (magnet and steel, remember)! Seems like some batches of glue held/hold better than others. Stop trying to be such a know it all, show-off hemorrhoid Effie! Contrary to popular belief........you really don't know every thing about everything.:smile:
  • gdb
    gdb Posts: 6,012
    dorokusai wrote: »
    Weird huh?
    Weird? Yes but, remember nothing ever happens.....until it happens!:biggrin:
  • dorokusai
    I've also never received a bad driver since 2003. Maybe it's simply packaging.
  • gdb
    gdb Posts: 6,012
    I've got approx. 75-80 frozen MWs with shifted magnets/pole pieces. (bought from ebay & Polkies) You've been very fortunate with yours so far!:smile:
  • dorokusai
    Sounds like the other end, not your end. Communincation breakdown perhaps? It's not luck.
  • dorokusai
    gdb wrote: »
    75-80? Really? I sell/sold vintage Polks thru CL, eBay, AG and private and not had that horrible affair. One of you is doing something terribly wrong and my attrition rate is 2-4 ....sorry, you're doing something wrong on one end. It happens, no doubt but you sould like a factory. You might be buying crap to begin with.
  • Vette C6.r
    GDB. You're not Magneto are you ??
    Sounds like you have really bad luck. Never experienced this before and I have traveled many hours to pick up speakers with MWXXXX's before.
    Sorry for your luck.
  • ben62670
    I have had numerous bad drivers being shipped from ebay.
    Ben
    F1nut Posts: 50,761
    gdb wrote: »
    Not to worry, you'll still be at the top of the clueless f*@k of the year list next year as well.
    75-80 bad drivers....Karma's a ****, ain't she!?!
  • dorokusai
    Well, while I've not had anywhere close to that historically, nor in reality, JBWeld them and move on with your life. GBD - I'd seriously figure out why your attrition rate is so high.
  • Knucklehead
    Knucklehead Posts: 3,602
    75 to 80? time for a change maybe?
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • gdb
    gdb Posts: 6,012
    dorokusai wrote: »
    No no, I bought them already in their frozen condition, for cheap,easily repaired spare drivers. I hoard stuff.:wink:
    http://www.polkaudio.com/forums/showthread.php?t=83674&highlight=frozen
  • gdb
    gdb Posts: 6,012
    Offhand....I'd say you're the beyotch!:tongue:
  • gdb
    gdb Posts: 6,012
    BTW, thanks for reminding me to bump my wanted thread!:smile:
