Projector choice and install questions
joeparaski
Getting close to buying again. I was looking into wire routing and was wondering what wires should I consider? HDMI of course is a must, but should I run every type of connector available from the PJ to the pre/pro just in case? And what is the maximum length I can go before I need some type of signal booster?(I read that somewhere).
PJ's I'm considering:
The Epson 8700UB....there's one for sale on the forum.
The Optoma HD20 ....a budget PJ that's supposed to be very good and I can get below $1,000 local.
Joe
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
I'm running an Epson 8500UB over 45 feet of Monoprice HDMI with no booster. I actually thought I was going to need one because of the length of my run, and I bought one... but with the booster in place, I got blue speckles and when I took it out, perfect picture. I highly recommend Monoprice's HDMI cable and wall plates, as it worked out quite nicely for me.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
Looks like we might have the same monoprice in-wall cable and potentially same repeater. Many have reported not needing any repeater but at one time, my HD DVD player started to go nuts on me withouth it and as soon as I installed it everything was fine. When we do our conferences, I have noticed issues at times with the PJs when the technicians aren't using DAs (repeaters) but it is random. The basic rule in AV, when using a cable longer than 50' it is highly suggested to use a DA amplifier (repeater). At the ridiculous price that monoprice sells them, I highly recommend yo buy one anyway, much better to have it on hand just in case. No fun having to stop watching your movie while waiting for a cheap part to show up at your door.kuntasensei wrote: »I'm running an Epson 8500UB over 45 feet of Monoprice HDMI with no booster. I actually thought I was going to need one because of the length of my run, and I bought one... but with the booster in place, I got blue speckles and when I took it out, perfect picture. I highly recommend Monoprice's HDMI cable and wall plates, as it worked out quite nicely for me.
I am using an Optoma and am very satisfied with the result however, it is a fact that the Optoma are budget PJs and Epsons are well regarded PJs so basically, you have to determine what is your priority. Budget concious or best VQ possible? Now, another point to consider is the forum asking price on the Epson and the remaining lamp life. If the price is right for you and if the lamp is near new and-if there is a spare lamp offered in the deal, maybe then its a no brainer. Just keep in mind most PJs lamps are expensive.DARE TO SOAR:
I'm extremely happy with my Epson 8100 and a 104" screen. I have a 50ft HDMI cable with the $13 (or so) repeater just in case.
Watch the Epson store; they have refurbished units at great prices now and then._________________________________________________
If you can manage the coin for the one in the FM, go for it. Much better PJ than the Optoma. If you think it's a tad to much then go for the Epson 6100/8100 which is better than the Optoma. Links and in stock
http://www.projectorpeople.com/projectors/projdtls.asp?itemid=26204&itmname=Epson+Home+Cinema+6100+B%2DStock
http://www.visualapex.com/Epson/Projector-Specifications.asp?For-The=Home-Cinema-8350Shoot the jumper.....................BALLIN.............!!!!!
