Polk rtia
Ok so as i mentioned before i have the rtia7 setup! but when i disconected the sub and only played bass through the speakers it sounded no diffrent the sub is really making me down! =/ is something wrong with it?! do i need a stronger sub?! the a'7s are hooked up to the xpa'3 should it be hitting the same?!
Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Sub...svs pc13 ULTRA
Amp:Emotiva xpa3
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Amp:Emotiva xpa3
Are the subs moving?
I think Pioneer does what a lot of Yamaha receivers do in that they set your front speakers to "Large". Check to see if yours did that and re-run the auto calibration with them set to small. I've read that's helped a few people wake up their subs in that situation.AUDIO - Fronts: Polk Audio RTI A9's | Center: Polk Audio CSI A6 | Sides: Polk Audio FXi A4's | Sub: HSU STF-1 | Receiver: Yamaha RX-V663 w/ AQ Type-4s | Amp: Rain MM-6 (300W x3)| Power: Panamax M5300-PM
VIDEO - Epson Powerlite 8350 Projector on Elite Electric100H Screen | Panasonic TH-42PX60U | Panasonic DMP-BD35 | Toshiba HD-A2 -
yes they are set to smal nd the thing is my brothers sony 8" sound harder at lower volumes in a bigger room nd he has it set in the middle by the tv?! aghh man really disapointing and yes the a'7s hit really hard! =] not the sub! =[Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Amp:Emotiva xpa3 -
Set them to large if you want more bass.
i got enough bass from the a'7s but as for the sub as i stated before only goes loud when i turn it up high on music on movies its perfect whats the deal?! i tryed placing it every where and i found the best spot but on music only loud with high listening levels! =[Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Amp:Emotiva xpa3 -
Ok, sorry just reread your first post. I thought you was saying the a7's wasn't producing enough bass.
Uhm, if I recall correctly...didn't you just purchase your sub?
Check the settings on your receiver, since it's your first sub maybe you don't have it setup properly on your AVR+rear of your sub. Also, don't expect much if you haven't broken it in yet.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
i just got it about 3 weeks from now!...i think....and im pretty shure i do phase is 0...volume is set around 2 a clock....and crossover at 80 ...+3db on avr iv tried it all the way no diffrence and i have it set broke in for about 70hrs!!Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Amp:Emotiva xpa3 -
Takes about twice that amount of time to properly break in speakers, especially subwoofers.
Phase will depend on placement/acoustics so unless someone was there physically we can't tell you whether it's right or wrong.
Do you have your subwoofer connected to your AVR via LFE?
Also, have you played around with placement? Placement is just as important as simply choosing the subwoofer you plan to implement into your system.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
yes i do have it conectec LFE and i was told i had it right on another post where i have pictures!.................and as i stated before i tryed every where and found a spot where it hits harder!! but not hard enough!Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Amp:Emotiva xpa3 -
It won't necessarily hit harder, but it could sound a bit 'boomy' or a bit more 'accurate' depending where it's placed as well as helping it blend in with your RTiA's.
As for phase, you want your sub's driver to be firing in the same phase as your main speakers. The difference is night and day if you listen carefully using a track with a steady bass-line. If the phase is wrong, you'll notice less bass because your sub's bass is competing/cancelling out the bass being played by your mains.
In this case, like you said when you shut it off/disconnected your subwoofer...the difference was minimal if any.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Agreed with the phase. If you suspect your phase is not correct, break out the SPL meter. When the sub is out of phase with the mains you should notice a drop in SPL or an overpowering in the lowest frequences and bass which is not full and even.
It's sometimes hard to do so, I know I had some trouble listening for it and my ears are still young!2Ch Tube Audio Convert -
Erik, I'm assuming you either did the speaker crawl to find the right placement for your sub or you used an SPL meter. Maybe your listening position is simply in a null? Have you tried looking at utilizing REW?HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
2CH: CJ MF2300, Parasound P3, PS Audio DLIII, Wadia 170i, Music Hall Maverick, Sierra-1s, Sunfire HRS8 -
yes i crawled went back to listening position and found the best spot and by best i mean better then the rest....wich is still pretty low =/......and i do have plastic tile does that affect the bass at all i know it does acousticly....if i add a carpet say a 5' by 7' in the room would i see/hear/feel the diffrence?!.....Ummm whats REW?!Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Amp:Emotiva xpa3
