Laptop to TV connection
NeilGabriel
NeilGabriel Posts: 1,487
edited December 2010 in Electronics
I have hooked up my laptop to the TV a number of times. But the last couple of times, all I can get onto the TV screen is the desktop and not anything in the browser....like the streaming episodes of Lie to Me....I toggle through all of the monitor options and still no luck.
Ideas? Thanks.
Post edited by NeilGabriel on
  • samnor
    samnor Posts: 155
    whats the connection? vga, dvi-to-hdmi? could be multiple problems... one thing to do is to check if the videocard is simply extending the desktop on to the tv in which case you will get a blank portion of your desktop stretching onto your tv. Make sure you switch the adapter to do a "mirror" which would then fix your issue.
    Fronts: Wharfedale diamond 9.6
    Sub: Wharfedale sw250
    Rears: Wharfedale diamond 9.1
    Center: Paradigm cc-350
    Pre-amp: Oppo dv981hd
    Amp for fronts: Parasound hca-1500a
    Amp for rears: Adcom gfa-5400
    Amp for center: Marantz MA500 monoblock
    Polk multimedia speakers for PC setup
  • NeilGabriel
    s-video to s-video....right now, I am sicker than ****.....I will do some more troubleshooting when my brain is functioning again.....thanks....
