1998 RT 55 i - Left / Right Shelf Speakers
hankster80027
I have blown out the tweeters in my 1998 RT 55 I Shelf Speakers. Both speakers have burnt cones and they obviously don't work anymore and I am trying to figure out how to repair them. The silver dome cones are burnt and I reckin' the tweeter / speaker is blow too...
I need advice on how to replace the cones ... and where would I look to buy the tweeter for them.
Hank
Hank
Post edited by hankster80027 on
The original tweeters are no longer available...even from Polk Audio. Polk sold a replacement silk dome (vs the original tri-lam)...but I'm not sure if it is still available. I actually like it better than the original. Call Polk CS and they can tell you what they have and the price. As I recall, even with a Club Polk Discount they were still around $70 each. They are nice speakers and well worth fixing...but if you need both tweeters, you are getting near the point where you might be better off looking for a nice used pair. You see them from time to time in the $200 range in very good shape."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
they don't make that tweet anymore? darn, those are nice speakers. beefy bookshelves the way God intended.
definitely call customer service, maybe they can recommend an aftermarket tweet that is closest to the parameters of the original? They'll have the best info either way....helpful bunch of folks.Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
