center channel mounting
silvertuner
silvertuner Posts: 496
edited December 2010 in Speakers
after my recent purchase of a cs-10 center, i ran into a problem of "where can i put this thing". i put it on the stand underneath my tv, but its about 2 feet BELOW the tv, and u can tell the sound is coming from a little low. messing with a few settings i was able to get it a little better but not as much as i would like. how do you guys mount your center channels? i was thinking on top of the tv and making a shelf myself out of pine or something. dont want it hanging out 10" infront of the television either. input? advice?
some cheap free sony speakers
psw125
denon 1610
3.1 channel because i hate cables ran across the living room like that
Post edited by silvertuner on
    EndersShadow Posts: 17,687
    What about this guy?
  • Knucklehead
    Knucklehead Posts: 3,602
    Just thought I would throw this out their....you can flip the center over and have it fire "upwards" if that makes sense.
    Check this out: http://www.polkaudio.com/homeaudio/tsi/index.php?s=cs10
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • silvertuner
    i have it flipped currently to fire upwards. just not working as well as i would like it. that shelf isnt a bad idea, but i still would have no way to really mount that to the top of the TV. im about to break out my damn epoxy and glue the **** to the top... lol jk jk.
    psw125
    denon 1610
  • Knucklehead
    Yeah, thats a shame brother, I would maybe experiment with some different mounting ideas on a sheet of paper and see what works best for you. Take a look at the system showcase and see if you can find any ideas there. good luck.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • silvertuner
    im thinking about buying some thin pine board and cutting it, putting a front lip on it, have it overhang the front about an inch, put a back piece to level it out, velcro it to the tv from the bottom... so it makes a sort of n shape with the back leg being longer and paint it black, and set it up there like a shelf. just worried about the bass rattling it off on those big impacts.
    psw125
    denon 1610
  • Knucklehead
    post a pic of what your working with, im sure something will become of it.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • jinjuku
    jinjuku Posts: 1,523
    Why wouldn't the shelf that Ender posted work for you? Just a few bolts into wall stud and you are done.
    Can you post a pic of your tv and surrounding area?
  • silvertuner
    i will post a picture in a bit and we can all join minds and think from there. gotta take the pregnant one to the doctor right now, but will post them when we get back
    psw125
    denon 1610
  • djperez81
    djperez81 Posts: 388
    the one Ender sent you should be nice and sturdy for your center and you can adjust the length of the arms on the mount.
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • silvertuner
    here is what im working with. the ledge infront of the TV isnt big enough to put the center channel on, already tried.
    psw125
    denon 1610
    OHHHHHHH....I GOT YOUR SOLUTION!!!!!!!!!!!!
    ITS RIGHT HERE!
    I use it w/ my CS2 and it works wonders, I forgot you had a DLP
  • Knucklehead
    ITS RIGHT HERE!
    Nice....good solution.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • silvertuner
    ITS RIGHT HERE!
    just ordered it, thx man! lol
    psw125
    denon 1610
    NP...had to contribute something to your build...since I have no plans to help you run wire :eek::redface::tongue::biggrin::wink:
  • silvertuner
    jerk! quarter round is all tore up on that side of the room, removing the baseboard once i get done going thru about 20 boxes of **** upstairs in a closet. in the meantime, i have Grandfunk Railroad on blast until the fiance gets back home lol.
    psw125
    denon 1610
    LOL...I always throw in some techno when I am cleaning/working myself. Love Pandora on my blu-ray player!
    You should think about running some Ethernet wires possibly to help you update your electronics easier....not sure if it would help you, but know you mentioned that in talking.....
  • silvertuner
    no way im running ethernet wires in this house lol. i only have 2 that can be updated, and both are in that picture. my 2900 is on the back burner and being sold, its not getting use with a 1610 so the SQ just wont be there, it will be overkill as a sacd/dvd audio player. convert everything to flac and run a cable from the laptop to the receiver when i wanna play music off this.
    btw... EWW TECHNO!
    psw125
    denon 1610
