Subwoofer Match for RTi4
GaryB
GaryB Posts: 15
edited December 2010 in Speakers
Hi Folks,
This is my first post. I just bought a set of (discontinued) RTi4 cherry bookshelf speakers from Crutchfield, along with the CSi3 matching center speaker in cherry. I notice the Polk website recommends the PSW111 as the matching subwoofer. However, it seems to only be available in black. Will something similar that's available in cherry (such as PSW10) work OK?
BTW: Are the RTi4 speakers considered at the same level in the Polk lineup (pricewise & qualitywise) as the current RTiA1 model? From doing a comparison, it seems the main difference is the RTiA1 has a taped cabinet whereas the RTi4 is more rectangular. Are there any other major differences?
Thanks!
Gary
  • leroyjr1
    leroyjr1 Posts: 8,785
    Both sound very similar, and yes the psw10 will be a perfect match for your setup.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    Gary,
    Welcome to Club Polk!
    I started with RTi4s, CSi3, and the PSW303 and it was a great value for the dollar. I think you will have ear to ear grinning enjoyment for quite some time.
    The RTi4s are, imho, a great gem and value for the money.
    The RTi4s are the older brother to the newer RTiA1s. Since you've made your purchase - don't even think twice about it.
    When you decide its time to upgrade, then you probably would be stepping up to a different line (like the LSi or its newer replacement).
    For now - enjoy the sonic goodness you are about to hear! :biggrin:
  • Ron Temple
    Ron Temple Posts: 3,212
    Don't know what your budget is, but don't skimp on the sub. If you stay with Polk go with at least the DSW line. There are lots of other brands that also do an excellent job (there's no timbre match for subs). In the budget realm, Lava is making some noise.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • packetjones
    packetjones Posts: 1,059
    Other than the cabinet shape they are basically the same speaker. In regards to the sub, any sub would work.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • GaryB
    GaryB Posts: 15
    Thank you, everybody, for the prompt and courteous replies! I've not yet rec'v my speakers (Crutchfield shipped them yesterday), but am already filled with excitement awaiting their arrival! From all I've read, they are great speakers. Thanks also for the subwoofer info; I wasn't aware that subs are not matched like the other speakers.
    Have a great holiday!
    Gary
  • aboroth00
    aboroth00 Posts: 1,108
    Look at some lower end SVS stuff. LIke the PB10s
    2Ch Tube Audio Convert
