Rear surrounds for RM6800 system
Polkuser10
I have a JVC RX-D702B receiver connected to Polk RM6800 speaker system in a 5.1 setting for the last few years. I am planning to add a pair of rear surround speakers. Any recommendations on what would be a good fit? I was thinking about the T15 which is available at BestBuy for about $100 pair
JVC RX-D702B Specs:
Surround System Class 7.1 channel .Signal-To-Noise Ratio 80 dB .Output Power / Total 1050 Watt .Input Sensitivity 270 mV .Amplifier Output Details 150 Watt - 6 Ohm - THD 0.8 % - 2 channel(s) ( Main ),
150 Watt - 6 Ohm - THD 0.8 % - 1 channel(s) ( Center ),
150 Watt - 6 Ohm - THD 0.8 % - 2 channel(s) ( Surround ),
150 Watt - 6 Ohm - THD 0.8 % - 2 channel(s) ( Surround back ),
150 Watt - 6 Ohm - THD 0.8 % - 2 channel(s) ( Front )
Thank You!
JVC RX-D702B Specs:
Thank You!
