Anthem multi-channel amp
misterwhisker
misterwhisker Posts: 49
I'm looking for an Anthem mca 3, 5, 30 or 50 amp.
I have an Anthem avm 20 and an mca 20 and I want to use them for my ht setup.
I would probably prefer a 3 or 5 only because I'm a cheap-**** and would be using it for the center and surrounds.
Thanks,
Brian
Post edited by misterwhisker on
  • dorokusai
    dorokusai Posts: 25,576
    edited December 2010
    Why not sell and get a full boat?
  • sm88
    sm88 Posts: 353
    I have an MCA50 for $1000, it's in fabulous condition with original box, manual, cord, shipping materials etc. I can deliver it or meet you part way;
    Current System:
    Paradigm Signature S2 v2
    Conrad Johnson MF2500
    Wyred4Sound DAC2
    Audioquest Black Mamba II
    For Sale:
    3x Wilson Cub's
  • misterwhisker
    I think the mca 50 is more of a pipe dream for me unless I can steal one on CL.
    I'll actually be up in Mass. next month but a grand is just way out of my budget.
  • sm88
    sm88 Posts: 353
    If you need 5 channels total you can likely get 500-600 for your MCA20, then maybe an MCA50 is poorer condition for 900ish, which isn't such a stretch. What is your budget, and do you have any other gear you don't need that you might be interested in trading? I'm always looking for new things to listen to and I've always got a treasure trove of amplifiers to choose from. PM me
    Current System:
    Wyred4Sound DAC2
    For Sale:
    3x Wilson Cub's
  • dorokusai
    That's what I like to see....barter....trade....let's work something out type deals.
  • misterwhisker
    Open to other multichannel amps as well.
    Rotel, Parasound, etc.
  • misterwhisker
    Found a Parasound HCA-1205a on CL.
  • sm88
    sm88 Posts: 353
    The one with the dead channel right? I warn you, that circuit board is covered in electrolyte that was leaked from the capacitors. It's a fantastic deal but the capacitors on the dead channel are blown, so i'd check the others out to be safe
    Current System:
    Wyred4Sound DAC2
    For Sale:
    3x Wilson Cub's
  • misterwhisker
    I pulled the cover off today.
    It's not electrolyte, it's actually the epoxy that they use for securing the caps to the board.
    They used copious amounts of that brown stuff on a few different components such as the thermal switches on the heat sinks.
    Tony from Parasound sent me the schematics for it so I'm going to troubleshoot it in the next week or so.
    I'm not doubting that it may have a bad cap but I'm leaning more toward a bad transistor.
  • ben62670
    ben62670 Posts: 15,969
    Most likely bad cap. If you were closer I could help:frown:
    Ben
  • sm88
    sm88 Posts: 353
    I had an HCA-1205A and had studied the internals. So when that particular one came up for sale with a bad channel I was the first person to write him to buy it, if it weren't so out of the way I would have, I really liked the Parasound. But I asked if he would check the internal fuses for me, and it blows fuses immediately when powered on. So I got him to send me a picture of the board for that channel:
    Doesn't look corroded like a leak but at the same time it seems odd that they would use it on just a few parts. I did not see it anywhere on the 1205A I had owned
    Current System:
    Wyred4Sound DAC2
    For Sale:
    3x Wilson Cub's
  • misterwhisker
    edited March 2011
    I finally got a chance to dig into the 1025a amp and found that two transistors were shorted(2sa1386 and 2sc3519).
    I swapped the transistors from another channel and the channel that was blowing the fuses is working great.
    I ordered the transistors today.
    A $5 fix and I'll have 5 working channels again :smile:
