Definitive word on SRS2 TL possibilities?
Loud & Clear
Loud & Clear Posts: 1,538
edited January 2011 in Vintage Speakers
This is what I have gathered using the search function:
1) It seems as though the blade/blade version can in fact be TL'd.
2) It also appears as though it's either impossible to TL the pin/blade version, or that no one has yet endeavored with enough conviction to do so.
Do I have this situation properly understood?
My reasons for asking are likely transparent. I have the pin/blade SRS2 and would like it very much if a TL procedure became available. Hopefully someone will come up with a viable solution at some point.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie
Post edited by Loud & Clear on
    nooshinjohn Posts: 25,466
    edited December 2010
    My understanding is that the pin/blade can be TL'd and the blade/blade cannot. I also understand that there are some pin/blade, such as the SDA-1c's that cannot be TL'd as well. Hopefully someone will chime in with information specific to your speaker.
    Toolfan66 Posts: 17,338
    Jesse would know, But I thought both could be TL'ed. I do know both P/B B/B 2B's can be TL'ed.
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
    F1nut Posts: 50,762
    I know a couple of the guys have TL's their SRS2's, BUT this mod has not been approved by Polk nor has any real testing been done such as frequency plots, etc.
  • helipilotdoug
    helipilotdoug Posts: 1,229
    My SRS 2 crossovers are being done by Ben as we speak. Jesse, what is involved in doing the frequency plots you mentioned? After they have broken in sufficiently, maybe I could do a plot, and post it so it could be available.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • Loud & Clear
    Is it known whether or not their SRS2's were pin/blade or blade/blade? I followed inspiredsports's threads on his blade/blade SRS2, but hadn't seen any pin/bladers giving it a try.
    Two Channel Setup:
    DAC: Arcam irDac
    Source: iMac
  • NJPOLKER
    NJPOLKER Posts: 3,474
    I venture to bet that the overwhelming majority of folks could not tell the difference between TL'd SRS2's and fully/properly upgraded SRS2's with RDO-194's.
    Maybe the RDO-194/SL-2000 SRS2 owners should spend the money else where like IC's or cables. I know I know the answer is "DO EVERYTHING" and do it now.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    RDO them and be done. Good lord.
  • TroyD
    TroyD Posts: 13,093
    RuSsMaN wrote: »
    ...the money shot.
    BDT
  • Loud & Clear
    They've had the SL2000 replacement tweeters installed. Solves some problems and introduces some others.
    I'll probably just take this question to a personal message level.
    Thanks.
    Two Channel Setup:
    DAC: Arcam irDac
    Source: iMac
  • dcmartinpc
    dcmartinpc Posts: 844
    Wanted to throw my 2 cents in the ring. I will be the proud owner of the SRS 2 Pin/Blade as of tonight around 7:00 PM! Anyways... I am going to be getting the crossovers upgraded by Ben, and would REALLY like to TL these if at all possible. I was given the email of the lead engineer at Polk and I have sent him an email asking about the possibilities of this mod for the P/B version. Hopefully I will hear back soon and we will have an official answer from Polk!
    Don
    Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
    Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
    Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
  • Hamatym
    Hamatym Posts: 269
    Really Nice Work!!
  • Big Dawg
    Big Dawg Posts: 2,005
    edited January 2011
    dcmartinpc wrote: »
    Don
    Ever hear back?
