Phono pre's <$500
steveinaz
steveinaz Posts: 19,547
edited December 2010 in 2 Channel Audio
Sans the usual suspects, Cambridge 604p, Nad PP2i, MMF, etc; what phono preamps (MC and MM capable) particularly impress you under $500 (OR suitable for a $1000 level TT)?
  • cstmar01
    cstmar01 Posts: 4,424
    Jolida JD9
    Granted I haven't had a ton of experience but this is a nice little unit that you can tube roll, do some mods to, and it sounds great.
  • ben62670
    ben62670 Posts: 15,969
    Jolida with caps and good tubes is nice.
    http://www.audiogon.com/cgi-bin/cls.pl?preaphon&1295279866&/Jolida-JD-9-Tube-Phono-Preamp-
    Edit: He beat me to it /\ :smile:
    Ben
  • madmax
    madmax Posts: 12,434
    I'd go used $1K $500 PS audio.
    Vinyl, the final frontier...
  • Dawgfish
    Dawgfish Posts: 2,554
    Another vote for the Jolida JD-9. Put some RCA 12AX7s in there and don't look back.
  • Fongolio
    Fongolio Posts: 3,516
    My Carver C-1 with upgraded caps and op-amps blows my mind daily.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • Face
    Face Posts: 14,340
    Jolida.
  • DON73
    DON73 Posts: 516
    ben62670 wrote: »
    Not meaning to hijack the thread but is the Jolida good the way it comes from the factory or do the mods have to be done first?
    TO ERR IS HUMAN. TO FORGIVE IS CANINE.
  • ben62670
    It's good, but much better modded. Just changing the tubes like Dawgfish said goes a long way.
    Ben
  • george daniel
    george daniel Posts: 12,096
    For SS,,the Dynavector P-75 is very flexable,both MM/MC's,, used for about 375 on A'gon
  • erniejade
    erniejade Posts: 6,327
    Project tube box II. If you can the se.
    Tony M Posts: 12,028
    Bob's Devices.
    Check into his work. I think he disrespected me but that's another story.
    He might make you a good pre if you know what TT is going to be with what amp for a while.
