Can someone help me understand these tech specs
phipiper10
http://www.soundstagenetwork.com/measurements/rogue_tempest_ii/
This piece is one item on my list but I haven't a clue from a technical standpoint what the heck any of that means or if it even matters? Any help is appreciated. (Generally I don't get too concerned with the tech specs, I am concerned with how it sounds.
Open to any other tube integrated under $2k also. (Still a possibility to do separates too but the pre would def be a tube)
I enjoyed my system most when I had the Anthem Pre 2l (and SE version) BOTH times. The space and air was terrific for me. If I can reproduce that space/air and with more detail then that is what I'm looking for.
I've considered Cary, Jolida and Cayin but my interest in them is fading. I like the power of the Rogues even the Cronus from them if upgraded has 90w.
Thanks,
Rich
Thanks,
Rich
Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
What do you want to drive with it?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
The Tylers in my sig, They are relatively easy at 92db. Thanks.Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
Are they 8 or 4 ohms?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
4ohmAnalog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
According to the spec sheet there is a big drop in power at 4 ohms. IMHO you may want to look at another amp. Others with more tube experience I am sure will chime in.
Ben
