Neotech wire
bikerboy
bikerboy Posts: 1,246
edited December 2010 in DIY, Mods & Tweaks
I needed to order some connectors from Soniccraft and also got some of the Neotech wire. I got the 3002 mid model and used cardas and Eichmann rcas on the ends. Very impressed. I have the Hageman cable burn in device cooking them in for 3 days. I listened for a while with 2 sets between the dac and pre and from the pre to the amp. Sounds great. More in a couple of days. Thanks George and others.
http://www.polkaudio.com/forums/showthread.php?t=101425&highlight=neotech+wire
Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w ONN Streamer, Sangean HDT-1X tuner
Vinyl: Nottingham Spacedeck->Pioneer PL L1000 linear arm->Soundsmith DL 103R w Contact line stylus->SUT->
Bottlehead Eros tube phono preamp
CD: DIY Shigaclone
  • ben62670
    ben62670 Posts: 15,969
    Are you using it for digital or analog?
    Ben
    Ben
  • george daniel
    george daniel Posts: 12,096
    good on you-- I'm starting my IC projuct after I finish with Eddies' cables--look at these--btw--that neotech is really good wire
    http://www.thecableco.com/product.php?id=6451
  • ben62670
    That looks good for my TT to Phono Pre. I have a hard wired stock wire there now. I have been looking at the Canare 4 wire.
    Ben
  • Outfitter03
    Outfitter03 Posts: 563
    Thanks for the heads up as I was looking at trying this. It is good to know that the Eichman RCAs fit around the 3002. Looking forward to the the rest of your review.
  • ben62670
    One thing I am not sure of though is if the capacitance of the 4 wire would be too high? Oh well back to spinning some Boz Scaggs.
    Ben
  • bikerboy
    I used the 2 conductor analog wire for the IC. The wire is 10.5 mm in diameter and neither the eichmann or the cardas rcas are big enough. If you remove the outer cover it will fit fine. I soldered the shield to the ground on the source end. Soon as they are done cooking in the hagerman frycleaner I will use heat shrink wrap to cover the ends. I'm working on a wireless remote controlled ldr preamp that will have balanced connections. When its done this wire will get vampire xlr connectors to replace the rcas. I bought 12 ft of wire so I will have 1-3ft, 1-2 ft, and 1-1ft IC. So for now the ICs are rca and when the balanced preamp I will convert them to xlr. Then I need to get the balance phono preamp finished. DIY is the way!
    http://www.soniccraft.com/products/wire/interconnect/neotech/nei-3002.htm
    CD: DIY Shigaclone
  • Face
    Face Posts: 14,340
    IMO, their solid core(chassis wire) makes a better I/C.
  • bikerboy
    Face,
    I used solid 28 ga silver wire before and liked it. I used cotton or teflon tubing for insulation and no shield. I thought I would try something different. This wire has a nice sheild but PE insulation. What ga and covering would you suggest for the chassis wire? Shielding?
    CD: DIY Shigaclone
  • Systems
    Systems Posts: 14,872
    Alot of this on Fleabay in all ga's up to 16ga:
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230546705334&ru=http%3A%2F%2Fshop.ebay.com%3A80%2F%3F_from%3DR40%26_trksid%3Dp4712.m570.l1313%26_nkw%3D230546705334%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1
    I was thinking of using the solid core Neotech 16ga pvc chassis wire to upgrade a power cord on a Rotel amp.
    I would twist it and put it in a tube.
    It has an 18ga/2 wire polarized plug now.
    Any reason this would not work?:confused:
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    bikerboy wrote: »
    Face,
    I used the same thing in my B1 Buffer, twisting the L and R channels. I prefer 20 and 24 ga as they're easier to work with and am not a fan of shielding.
  • zingo
    zingo Posts: 11,258
    pepster wrote: »
    Make sure that it is rated for the voltage.
  • bikerboy
    The wire is sounding great. Typing on a droid x for the first time. LZ ll Moby Dick sounds very direct and clear. Maybe too much edge but we'll see or hear as it is.
    CD: DIY Shigaclone
