Problem with PA 1100.5
![greg2350](https://wf.vanillicon.com/fbdf5bad569406a17b3c0142e4348383_100.png)
greg2350
This problem started a few months ago. I went to adjust the sub gain on my amp and noticed the gain control wasnt there!!! upon further look the gain control had dropped down in the chassis. I took a small flathead and moved it back up. After a couple of days I checked it the gain control had fallen back down I moved it back up. This kept happening more often, now when the gain control falls down I get no sound from the sub. When I move it back up sub comes back on. Im thinking it moving up and down caused a solder joint to come loose. I called polk CS and the amp is out of warranty and he could not give me a price to send it to them and fix it. I dont really have the funds to fix it do you guys think I could resolder the gain control im pretty good with a solder iron. Im guessing this amp uses a multilayer board. This amp is in a hatchback and has never got to hot maybe a little warm never pushed hard. What are your thoughts on this. I attatched some pics after I moved the gain control back up.![:smile: :smile:](https://forum.polkaudio.com/resources/emoji/smile.png)
![PA11005_SubGainMeltingPoint.jpg](http://i325.photobucket.com/albums/k373/greg2350/polk%20amp/PA11005_SubGainMeltingPoint.jpg)
TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX
AVR: Denon 3801
Sat: Directtv HD 10
If I were you I'd take it apart and have a look at it since its out of warranty anyway.
Careful with those caps though, they can hold a good amount of juice!Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Polk SR104Any clue how to use the internet? Found it in about 10 sec.
