Monitor front re-painting
wingman1659
wingman1659 Posts: 3
edited December 2010 in Speakers
I really like the black face of the Monitor II's but for I only have the II's for my surrounds.
Is there any way to take off just the silver plastic and repaint it in the black color to match my surrounds? Thanks for any help
  • Glowrdr
    Glowrdr Posts: 1,103
    I'm sure you could get away with it - just be sure to do it right. By that I mean take the speakers out, remove them from the surrounds, and spray the surrounds. Don't just "grab the smallest brush you can find and wing it"
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • mdaudioguy
    mdaudioguy Posts: 5,164
    You might find this thread useful: http://www.polkaudio.com/forums/showthread.php?t=29186
    Good luck! :smile:
  • dorokusai
    dorokusai Posts: 25,642
    That thread...and Krylon makes some awesome stuff. Spray paint ain't what it used to be.
