Calling all electricians
kevhed72
kevhed72 Posts: 5,079
edited December 2010 in The Clubhouse
I am moving my HT to the basement and need to re-do the electrical for lights.
There is a circuit from the breaker box leading to a switch which controls the lights for the whole basement. QUESTION - can I simply add a junction box to this line before the existing switch, and splice off another run of wire to another switch to control another set of lights?
Post edited by kevhed72 on
  • gdb
    gdb Posts: 6,012
    Simple answer? Yes. It may be easier to run out of the existing box, unless there is a lot of slack in the cable to enable you to sever it and still have enough length inside the new box to make your connections.
  • kevhed72
    gdb wrote: »
    Good deal...thanks man. I was able to pull enough slack out of the existing run to make this work.
  • Midnite Mick
    Midnite Mick Posts: 1,591
    You may want to check with local codes. In my locale we are limited to 12 items on a single circuit.
    Regards,
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
