XO upgrade components
JimMueller
JimMueller Posts: 100
edited December 2010 in Vintage Speakers
I was planning to get the caps from Parts Express (027-252, -260 & -419) & Madisound (ESA 12uF), and the resistors from Sonccraft (MRA-12's). When I mentioned getting the Dayton's from PE, they said the Sonicaps are better and U.S. made. But then I would need to use a pair of 20uF instead of a single 40uF Dayton. The Sonicap's are 200V whereas the Dayton's are 250V.
I was planning to use one of those new custom PCB's listed in another thread. For fitment, should I opt for the pair of 20's or the single 40, and will there be a noticeable difference between Dayton & Sonicap?
Yamaha RX-2600 receiver, Nakamichi Dragon, Mitsubishi HS-U80 VCR, Pioneer DVL-90 LD Player, Sony BDP-S550 Blu-ray player, Sony CDP-X555ES CD player, Carver TFM-42, Carver AV-634, Panasonic TC-P54V10 plasma, BenQ W1070 PJ, Fisher MT-90 turntable, AKG-K340 headphones, Polk SDA-1C mains, CS-400i center, FX A4 surrounds, Rti A1 surround backs
Post edited by JimMueller on
  • NJPOLKER
    NJPOLKER Posts: 3,474
    I would contact Sonic Craft for everything. They have more than what's on the web site available.
    http://www.soniccraft.com/index.htm
    Money well spent on the sonicaps by the way. Thank me later :rolleyes:
    Search this web site for all kinds of excellent information. The search function is your best friend other than your right hand :tongue:
  • Vette C6.r
    Vette C6.r Posts: 1,560
    +1
    They are have a 20% off sale till I believe Dec 17th or so. Better jump on that.
    F1nut Posts: 51,713
    That's not a problem.
    So what, the originals are 100V.
    Yes.
  • ben62670
    ben62670 Posts: 15,969
    This is for your 1C's correct?
    Ben
  • JimMueller
    I received and installed the 194's this afternoon. Turned on the tuner and will let it play continuously around 70dB for awhile... at least when I'm not sleeping. Is the consensus 300 hours before they're broken in?
    I also received Larry's driver mounting rings yesterday. I'll probably hold off on installing the planar rings because I can't install them without disassembling the cabinet.
    F1nut Posts: 51,713
    I'm sure you meant the PR rings, there's nothing planar about SDA's. You bend them at the two areas with the small cut outs, insert into the cabinet, then bent them flat again. You cannot disassemble the cabinet.
  • JimMueller
    Yeah I meant passive and typed planar, sorry. I didn't receive any docs on how to install the rings, so I assumed the PR rings could only be installed by those folks who rebuild their speakers by completely disassembling them.
    F1nut Posts: 51,713
    No one disassembles the cabinets.
    Do you see the little cuts I mentioned?
  • JimMueller
    I won't have a chance to look for the little cuts until this evening.
