SL-2000 Question
Namikis
Namikis Posts: 14
edited December 2010 in Vintage Speakers
One my SL-2000 tweeters in a pair of 5Jrs has the two very thin lines on the done (se pic) - you almost can't see them. Sound is fine - just wondering if this is normal.
Thanks,
Namikis
    Toolfan66 Posts: 17,338
    I have had a few that way, not sure how it happens but it won't affect the sound..
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • dorokusai
    dorokusai Posts: 25,577
    Not exactly normal but not uncommon in any way. Should have no impact on the sound or resale value.
  • Namikis
    Namikis Posts: 14
    Thanks - appreciate the input.
