coax question
scottyboy76
scottyboy76 Posts: 2,905
edited December 2010 in The Clubhouse
Cable company hooked up our internet modem using 18 gauge coax.
I want to run an extension to move modem.
I have a bunch of 14 gauge.
I always thought the lower the no. the thicker the wire and the better.
however the cable co. wire is thicker overall and before i crawl up under the house i want to be sure im not **** it up.
Any advice would be greatly appreciated.
humpty dumpty was pushed
Post edited by scottyboy76 on
  • Cpyder
    Cpyder Posts: 514
    Probably just thicker insulation. Shouldn't matter if you use your 14.
    Edit: Wait. Up under the house? Are these wires running outside? Then, insulation may play a larger role.
  • steveinaz
    steveinaz Posts: 19,538
    RG-59 usually has a 22awg center conductor, where RG-6 has an 18awg center conductor. Never heard of 14awg coaxial cable...?
  • nguyendot
    nguyendot Posts: 3,594
    That's what i was thinking.. you don't see coax measured with gauge...usually it's the type RG-**** and based on that you get a size/rating.
    Main Surround -
  • ben62670
    ben62670 Posts: 15,969
    You have a bunch of 14ga what? If indeed it is coax I doubt it is 75ohm. Go buy some of the right wire.
    Ben
    Ben
  • scottyboy76
    you cant take a step around here without learning something.
    thanks for all the replys, i always thought all the thick black stuff was coax.
    also the resistance was something i never thought about in regards to video or data transfer.
    again thank you.
