6511 popping at high volume
erniejade
erniejade Posts: 6,321
edited December 2010 in Vintage Speakers
OK the simple solution is to turn it down LOL It seems one of the 6511 drivers sounds like its farting after a bad night of beer and white castle LOL Now this only happens when kicked hard. At softer normal volume it sounds fine. Do you think it just might be a coil rub? If so, is this fixable or does it need to be replaced? It is the right side, top inner 6511.
How did it pop? Sunfire sig 625x2 on the sda 2.3 at a nice concert volume. The music was Fleetwood Mac The Dance, opening kick drums on the chain. BTW if you are a fan and don't have that cd, the quality is great and sounds wonderful on the SDA's.
Post edited by erniejade on
  • Conradicles
    Conradicles Posts: 6,343
    Sounds like voice coil rub to me. I'd replace the driver and call it a day.
  • leroyjr1
    leroyjr1 Posts: 8,785
    What kind of volume is the driver popping at? (spl)
  • ben62670
    ben62670 Posts: 15,969
    I am going to bet the driver that pops is blown. When they go they act like little passive radiators that are over driven by the other drivers. Pull the suspected driver out and take an ohm reading.
    Ben
    Ben
    F1nut Posts: 51,787
    Toasted.
  • dorokusai
    dorokusai Posts: 25,576
    Agreed. It's bad, buy a new one. Pull it out, take an ohm reading then throw it in the garbage.
  • erniejade
    looks like I will be calling polk tomorrow. It gives me a good excuese to get the RDO's for them at the same time.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Blown in mind also.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
