Polarized C7 power cables
quadzilla
quadzilla Posts: 1,543
edited December 2010 in Electronics
So apparently, the hardest cable to find is a polarized C7 connector. I've found lots of companies making unpolarized (that figure 8 looking connector), but can't find anyone that does a polarized C7. Anyone know of such a critter? Also, I'm not looking for a "cheap" cable. I'm looking for something like the Pangea C7, but polarized.
Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Post edited by quadzilla on
    F1nut Posts: 52,043
    PS Audio use to make one, not sure if it's still available.
    http://www.psaudio.com/ps/products/description/xstream-power-punch-c7?cat=classics
  • quadzilla
    Thanks, but not available anywhere I can find. Cardas made one too, but that one seems to be gone now as well. I'm about ready to mod my Pio DV47 to take a standard plug.
    Arm: Rega 300
  • Face
    Face Posts: 14,340
    SignalCable now carries one: http://signalcable.com/digitalpowerHC.html
    Don't forget to ask for the Polkie discount.
  • quadzilla
    Thanks, but those are all non-polarized, and the device expects polarized power.
    The adapter is polarized, and unless I can find a cable that's polarized, I'll probably have to go that way, though I have pretty strong doubts that the device will handle the weight of the adapater plus cable.
    Arm: Rega 300
  • dorokusai
    dorokusai Posts: 25,576
    The C7 connector will not change....its a standard. The polorized or grounding happens on the othe end. What are you trying to do? The equipment will not know polarized from non-polarized. You sure that its not a C5 you're looking for?
  • quadzilla
    Definitely C7, and according to what I've found, some equipment does expect polarized power. That's why some C7 connectors have one side that's flat. That's a polarized C7.
    Arm: Rega 300
  • dorokusai
    Quad - Yep, I forgot all about that little caveat. That's exactly right. Why not call and ask Frank @ Signal to get a polarized Furutech. It's now an option with him and they do make them.
  • quadzilla
    I was thinking of trying him. Haven't been able to find a polarized C7 terminator from anyone, or would have just lopped off the end of an extra Pangea and made my own :) That and he only lists the non-polarized connector on the site. I need to holler at him anyway though because I've been needing to get a power cord for my TV with a right-angle connector.
    Arm: Rega 300
  • dorokusai
