"This is my wife and her 496 Chevelle."
mrbigbluelight
mrbigbluelight Posts: 9,897
edited December 2010 in The Clubhouse
No, no .... that's not MY wife ..... just a quote from the guy shooting the video.
(that would be too much like RIGHT and it seems the Big Guy Upstairs was asleep at the switch when it came to passing out wives :rolleyes: .... couldn't be my fault)
Anyhow ... had to look up a video after watching Sal's video on the hippity-hopper cars and to pass on a little advice to you young whippersnappers.
If you want to mod your car ( Good thing ! ) to impress the ladies ( Understandable ), do it right.
If your mods involve 95 % hydraulic work, 5 % mechanical, than you're going in the wrong direction. IMO.
Nope. Get some good ol' fashioned iron (no offense to you rice burners).
Probably have to do a little body work, maybe a few engine mods although that may not even be necessary.
This guy's WIFE managed a sub-12 run on pump gas with a mild cam and a 3:31 rearend, for gawd's sake.
3:31 rearend .... heck, that's what your grandma's got in her station wagon to haul groceries !
Which is, according to the guy, what his wife does: hauls groceries and the kids, too.
So, gentlemen, if you're going to mod a car, and you want one of the ends of the car to lift, don't cheat. Don't go with your fancy-schmancy hydraulics with the rear hippity-hopping up and down all cutesy-pie-like. (if you're interested in hydraulics, get a job at the Hoover Dam).
Nope. Get that front end lifting with some good ol' fashioned American iron.
It's been scientifically documented that this will impress the ladies. Besides .... I said it was so, and my knowledge of women is ..... awesome ! :eek:
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/2vDqxcTx8xg?fs=1&hl=en_US&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/2vDqxcTx8xg?fs=1&hl=en_US&rel=0&quot; type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Post edited by mrbigbluelight on
  • woodhead 2
    woodhead 2 Posts: 367
    Right on!!!
    Panny 8000 project
    Oppo 103D
    Fronts- Monitor 70's
    Upper fronts- Monitor 30's
    Surrounds- Monitor 50's
    Backs- Monitor 40's
    Center-CS 350
    Sub- SVS PB 2000
    Onkyo 607[back up]
  • faster100
    faster100 Posts: 6,124
    yeah but looks like an 1/8 mile track close as the traps are in the video
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • Face
    Face Posts: 14,340
    Very cool!
    faster100 wrote: »
    Nope.
    tonyb Posts: 33,030
    Nice....had a 396 Chevelle,fast car. Wish I still had it,worth some coin today. I love the older muscle car engines. You could work on them yourself without all the computer crap on todays engines.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Yea I'm confused by the 496... Chevy made a 396, 427, 454, 350, 327, 307, but not a 496 what is that?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • AudioGenics
    AudioGenics Posts: 2,567
    496 ....454 bored .060 with a 4.250 stroke and a 6.385 rod or 6.135
    the bore & stroke is what makes it a 496....4.310 bore & 4.250 stroke....the 6.385 rod is 4 the tall deck
    I googled it.
  • WilliamM2
    WilliamM2 Posts: 4,784
    I googled it.
    It's also mentioned in the first comment below the video on You Tube.
  • AudioGenics
    F1nut Posts: 50,870
    Nice car!!!
  • Jstas
    Jstas Posts: 14,849
    What are you babbling on about now?
    A few things.
    Hydraulics are mechanical. If all of a sudden, they aren't, that's news to me. Just because they are actuated by fluid pressure doesn't mean it isn't a mechanical action.
    What's body work have to do with anything? What if the car's straight as an arrow with gorgeous original paint? Does it make it any less of an impressive ride? Don't answer because the answer is no. If anything, it's more impressive and more valuable.
    Mild cam? With 496 cubic inches, it's making some power. But the engine was built by a pro and is honestly kinda weak. The dude is sand-bagging the description too 'cause a "mild cam" and a displacement increase doesn't make 150+ more horsepower over stock either. He has more done. Popular Hot Rodding built a 496 out of a beat up truck engine a few years ago and pulled 578 horses on an engine dyno on what is a mild build and included new cylinder heads. New heads are not worth a piddly 30 horsepower. Especially not with all the valvetrain upgrades done. Besides, his power band is likely in the sky if he needs a 3500 RPM stall converter. It must be a pain in the rear to drive on the street. "Leah" should stop **** around with the used E/T's and get a set of cheater slicks or new slicks. She should also have a trans brake and be standing on that throttle at the tree. She'd probably hit 10's if he courage didn't run out first.
    Grandma's station wagon likely has a 2.60:1 final drive. 3.31 or close to it is what's available in many cars like Mustangs and Camaros now. Then again, with today's larger wheels and tires, it's more routine to see 3.30-4.10 to 1 final drives because they compensate for the bigger overall wheel height. This makes them perform like more economical 2.40-2.90 to 1 final drive ratios.
    I didn't see that Chevelle lift a single wheel off the ground. So I have no idea where that's coming from. That 'bu did though and quite well I might add but it was a far cry from that Chevelle.
    I will say it's a nice car. High 11's is pretty good for a nose heavy 3600 pound pig. Could probably stand to lose a few pounds without sacrificing driveability and comfort.
    I don't disagree about heavy iron making big power easily and twisting frames but you could have found a much better example that illustrates your points better.
    Like this one:
    <object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/qNGtrQ0gvWo?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/qNGtrQ0gvWo?fs=1&hl=en_US&quot; type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
    or this one:
    <object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/uvfjCyzeWfc?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/uvfjCyzeWfc?fs=1&hl=en_US&quot; type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
    Here's the Popular Hot Rodding article:
    http://www.popularhotrodding.com/tech/0806phr_chevy_496_big_block_engine_build/index.html
    Expert Moron Extraordinaire
    F1nut Posts: 50,870
    Geesh John, take a chill pill.
  • faster100
    Face wrote: »
    Very cool!
    Nope.
    Does it say somewhere, just curious. looked like a short track to me.
    Very clean car, looked like a pooch off the line but looks nice
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • audiobliss
    audiobliss Posts: 12,518
    Haha, that was definitely not an 1/8-mile track.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Face
    Face Posts: 14,340
    There are a few things that can affect how the car traps in comparison to E.T. Optimum power band in relation to gearing and converter, how hard it launches, weight, aerodynamics, etc...
    I.E., my 99 Regal ran a 13.58 @ 98mph. I added a few more mods and then ran a 13.52 @ 100.3mph due to making more hp up top. My 98 C5 ran 11.6 @ 114 with a 1.6 60'. I added another 70+ hp and ran a 11.02 @ 120 with a 1.49 60'. The car still launched hard and power was added almost evenly throughout the powerband.
    Have you ever seen the average modded Supra at the track? It's funny to see them run 12's @ 130mph due to soft launches and not making much power down low without spray.
  • Sherardp
    Sherardp Posts: 8,038
    Love it, kills the Hondas and Toyotas all day.
  • faster100
    didnt pay attention to the mph, def not 1/8 mile @12 sec run
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • greg2350
    greg2350 Posts: 544
    Nice 70 chevelle heres some pics of my 70. Mild 454 more street than strip.
    TV: Philips 42" LCD 1080p
    Front Speakers: Polk Audio RT800i
    Center Speaker: Polk Audio CS1
    Surround Speakers: Polk Audio R50's powered of Denon AVR
    Subwoofer: Polk Audio DSW pro500
    AVR: Denon 3801
    DVD Player: Denon DVM 745 upscale 1080p
    Sat: Directtv HD 10
    Front Speakers Amp: Rotel RB 890
    Center Speaker amp: Rotel 970 BX
  • read-alot
    read-alot Posts: 812
    I knew the Hot Rod pros of this forum would pick apart this one.
    Tell your wife this old hot rodder was impressed and to keep on keeping on.
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • mrbigbluelight
    All good ! My expansive knowledge of women has been known to inspire outrage before.
    ...mainly by women, but that's besides the point
    Jstas wrote: »
    A few things.
    Hydraulics use fluid motive power to achieve a mechanical action.
    Hydraulics is the primary, driving force; the result achieved is through mechanical action (driven by the fluid motive force).
    So unless we're putting liquid mercury into our brake lines, hydraulics should not be considered mechanical.
    I agree, but Jstas ... you're missing the point of my original post: trying to get today's misguided youth back on the straight and narrow track to Babe-dom (and the acquisition thereof).
    The point is: Get some old iron. Mechanically, as-is, if it's working you're halfway home. Now if the quarter-panels are rusted out, or the headliner's drooping to the floorboard, ... that's no good. The ladies don't like that. You've got a little spucing up to do.
    If it's straight as an arrow, with gorgeous original paint, you're home, brother !
    Better stop at Walgreens to pick up some .... well .... :redface: .... you're going to need 'em !
    While it would probably have been more accurate to describe it as a "relatively mild cam", it definitely wasn't a hot cam. Without looking at a spec sheet, there's a couple of ways to tell; by sight and sound.
    Get a hot enough cam in an old piece of iron, and it'll rock the car at idle.
    You can see it.
    Get a hot enough cam, and you can be blind, and know it's a hot cam by the "BLAAAT BLAAAAT BLAAAAAT" factor at idle. You can hear it.
    Old School Rule of Thumb: The hotter the cam, the hotter the chick.
    ( involves sonic waves inducing euphoria into certain regions of the female brain ..... it's all scientific stuff. But it's true ! )
    With my well-trained eye for the well-turned ankle, I think we should allow Leah a little fun driving to the grocery store with the kids. She's good at the track, she's obviously a good cook, good with the kids (rides to the Shop n' Save are probably the highlights of the kids' day as Momma lays rubber at every stop sign), good looking ....... Jstas, this is the point I'm trying to drive across to the youngsters today ! You're not going to get that kind of package driving around in a 50-cc rice burner, with Thrush mufflers to make it "sound good", hippity-hopping in the 7-Eleven parking lot. Nosireeebob !
    (for proof, look at the "ladies" attracted by that style of car in Sal's video).
    Agreed that today's tires are higher. Actually the rims are higher, with 1/8" of rubber around the circumference. What's up with that ?
    Nope, time to go Old School again, where one big old set of fatties on the rear end practically took the dailey production from the North Slope oil fields to produce.
    Old School Rule of Thumb: "More rubber will require more rubber". :redface:
    Agreed that the Chevelle's front end didn't come off the ground, and that's a good thing. But that again proves the point I'm trying to make: Just because you can get your car hippety-hopping doesn't mean you're going to be bippety-bopping later. And that's valuable information that I'm generously willing to share from the Vaults of MBBL'S "Secrets of Women" ! :eek:
    I like the one I posted; nice car, nice looking gal, the whole schlemiel !
    (Did I mention that she cooks, too ? And .... nice looking ?)
    http://www.popularhotrodding.com/tech/0806phr_chevy_496_big_block_engine_build/index.html[/QUOTE]
    Nice article. I've been thinking about publishing an article on "Hot Rodding", but ... well ..... don't want to give away all my secrets.
    :smile:
  • gdb
    gdb Posts: 6,012
    Touche' Sir ! (clapping smiley here):smile:
  • audiobliss
    Hooray, sir!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • stuwee
    stuwee Posts: 1,508
    Great fun! Thanks! My '70 RS/SS split bumper Bad Boy
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • sda2mike
    sda2mike Posts: 3,131
    big cubes = big tourque...you could run a 2.73 rear and still kick ****..plus it would be docile until called upon:wink:
