RTA12 Tweeter Xover Plug change
brgman
brgman Posts: 2,859
edited December 2010 in Vintage Speakers
Ok so i am trying to swap my RTA12 parts from some old nasty cabs to some nice ones i got from keith.The plugs on top are hot glued to death on both.Any suggestions on how to remove these so i can swap them?
I need to do this because the 12C xovers are different than the 12's i am taking out so wiring is different (or missing).:redface:
Mike
I’M OFFENDED!!!!
Post edited by brgman on
  • dorokusai
    dorokusai Posts: 25,576
    That hot glue should be easy to pry off the cabinets and connectors with a pair of pliers or my favorite goody box tools....dental picks. You can buy them at Home Depot and are a must have for vintage Polk work. It's usually pretty brittle and barely in an adhesive state anymore.
  • brgman
    brgman Posts: 2,859
    thanks.I didnt want to start going at it and be missing some other tactic.
    I’M OFFENDED!!!!
  • dorokusai
    I've dug into dozens of old Polk's with the picks and been just fine. It either chips off or pops off en masse. It's worth your time to poke at it. If it doesn't give as described, and don't be shy, back off and report back.
    I bet it pops off just fine.
  • AudioGenics
    AudioGenics Posts: 2,567
    might try isopropyl alcohol
    comes off easily without picking
    http://www.youtube.com/watch?v=dNNqSXgj6DE
  • geppy1
    geppy1 Posts: 3,076
    What they said. You will have to pull the plug out from the top. Also has the cabinet you are moving it to is slightly smaller i would put more insulation in it. to make the drivers think it is bigger. I would get rid of the yellow thing and put the insulation from your 12Bs in the new cabinets just the way it was in the old ones. Then get some extra from JoAnn fabrics. Those are very early cabinets. I had a pair of later early 12s and they were stuffed with the white insulation.
    Pretty nice cabinets aren't they??
  • brgman
    brgman Posts: 2,859
    very nice cabs keith.picking away at the glue right now.slow but sure.i will see that i stuff the bad boys with the white ins from the C's.
    glad you packed them so well.my wife said she looked out and saw the fedex guy toss them onto my concrete porch like they were on fire.sometimes i think these guys take the "fragile" stickers as a challenge to see how bad they can treat them.
    I’M OFFENDED!!!!
  • dorokusai
    I's stay away from the alcohol since the long term effects can effect the laminate. Just take your time. You in a hurry?
  • brgman
    brgman Posts: 2,859
    No hurry.
    I just got the first one out but a wire broke off of the lower crossover so now i am gonna have to learn the fixin' process for that.
    this IS my first rodeo with this stuff so i am taking it slow.
    thanks for the support
    mike
    I’M OFFENDED!!!!
  • geppy1
    geppy1 Posts: 3,076
    You have to disconnect the wires from the lowerer X over or cut them and then reattach
  • brgman
    brgman Posts: 2,859
    when you say cut and reattach is it a sin to use wire nuts to reconnect?
    I’M OFFENDED!!!!
