Adcom HT preamp/amp - $250
RuSsMaN
RuSsMaN Posts: 17,985
edited July 2003 in Flea Market
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3035913796&category=3280
Has remote, and DB25 5.1 input for you guys with 5.1 outs on your dvd players. Also has built in center and rear amps.
Might be worth a look, no affiliation.
Cheers,
Russ
Post edited by RuSsMaN on
  • Ron-P
    Ron-P Posts: 8,520
    edited July 2003
    Not a bad deal. I'll have to research this little gem, thanks Rusty. No dts, but I could still keep my Marantz for that.
    Peace Out~:D
    If...
    Ron loves a film = don't even rent.
  • Ceruleance
    Ceruleance Posts: 991
    edited July 2003
    as someone who has looked into this kind of equipment, I personally think thats gonna turn out to be pretty useless and way overpriced. (those models usually go for cheaper than that opening bid) It was designed for people with stereo systems that were just converting to surround sound.
  • RuSsMaN
    edited July 2003
    Ron, unless your player holds the processors (dd/dts) as mine does, this unit won't work for you needs (be able to decode those signals).
    Cheers,
    Russ
