RTi A9 speaker abnormality
Stirling
Stirling Posts: 22
edited December 2010 in Speakers
Hi
I just received my new RTi A9's 2 days ago and just noticed a abnormal top midrange driver discoloration. I don't notice any sound issues but being a brand new( expensive) purchase I am curious if it is the start of material breakdown or water/chemical contamination during the manufacture process
I attached 2 pics to show a good a not so good looking speaker
thanks...
  • mdaudioguy
    mdaudioguy Posts: 5,164
    I would think that Polk will replace that, if your purchase was through an authorized dealer. Call them on Monday (# in top, right corner of screen).
  • Stirling
    Stirling Posts: 22
    I bought them through Crutchfield...It sucks that I have to drive all the way to TO 2 days after receiving them...you would think they would see something like that during manufacturing...I'll give them a call on Monday
    thanks
  • dorokusai
    dorokusai Posts: 25,640
    Stirling wrote: »
    thanks
    Well, they didn't catch it. And it could have happened after production, during packaging, during the -30deg FedEx flight from China, maybe when the newly hired holiday truck stuffer tossed it in the tractor trailer....who knows. I bet that it gets taken care of in a jiffy from Crutchfield and/or Polk Audio w/ ZERO driving involved...problem solved.
  • dorokusai
    Stirling wrote: »
    Hi
    thanks...
    It's certainly weird. I'm sure it's just that and I'd be more concerned if you actually heard a difference. It's just a dust cover and has nothing to do with actual sound.
  • Stirling
    Stirling Posts: 22
    I realize the many steps involved and I hope you are correct about the zero driving....they sound beautiful and I don't want to let them go!
  • Stirling
    Stirling Posts: 22
    if it just a dust cover what would be the audible difference ( if any) if say this issue caused the cover to eventually dry and crack?..it does LOOK weird though..
  • AudioGenics
    AudioGenics Posts: 2,567
    Questionable quality control
    otherwise its speculation what occurred
    Your warranty should cover the replacement.
    F1nut Posts: 52,350
    Stirling wrote: »
    Zero audible difference, it's just a dust cover. Stop worrying, Polk will make it right as they have the best CS around, period.
  • Stirling
    Stirling Posts: 22
    thanks F1nut and everyone...first big speaker purchase and without knowing what the cause is by nature there is always a bit or worrying:biggrin:
  • falconcry72
    falconcry72 Posts: 3,580
    otherwise its speculation what occurred.
    It's also speculation that it was questionable quality control...
  • falconcry72
    Oh and Stirling,
    Welcome to CP, and that's a badass speaker you got there!
  • mdaudioguy
    Crutchfield is very good, too! Either/or - you'll be taken care of PRONTO!
  • AudioGenics
    agreed...
    IF the speakers having passed QC had left the factory distribution in its' original sealed packaging to the dealer and then to the customer intact .
    IF the packaging were resealed then all bets are off.
    Wonder if there is any evidence that the cartons were opened and resealed ?
  • Stirling
    Stirling Posts: 22
    the cartons looked super sealed...
    I will post again on Monday once I talk to someone
    S
  • Stirling
    Stirling Posts: 22
    thanks falconcry72
    just finishing putting together my first and most likely last HT system for awhile ...VISA is cooling in the freezer!:eek:
  • Sherardp
    Sherardp Posts: 8,038
    Welcome to CP. As the others mentioned CF or Polk will definitely get you taken care of. Had a problem with a driver in my Rti12s, and CF had me a replacement in 4 days and that was fast considering I'm in Japan.
  • Stirling
    Stirling Posts: 22
    Hi Sherardp
    Did they replace the whole speaker....or just the driver... if so did you instal it?
    Because mine doesn't exhibit any issues sound wise..purely cosmetic as I have been told I am not sure how to proceed but I will talk to them Monday anyway
    thanks
    S
    F1nut Posts: 52,350
    Remove the 4 allen head screws, pull out the driver with the silver trim ring, detach the two wires noting where they go, install the new driver.
  • Stirling
    Stirling Posts: 22
    pretty simple...are they soldered?
    S
    F1nut Posts: 52,350
    No, push on terminals.
  • Stirling
    Stirling Posts: 22
    very easy then!...if it comes to that.
    Thanks F1nut
  • [Deleted User]
    [Deleted User] Posts: 1,223
    Yes by all means customer service should take care of this pronto. Call them first thing Monday. :cool:
  • dorokusai
    I love the "...questionable quality control..." comment. This could have happened at anytime and to immediately suggest poor quality control based on a single post, on a single forum, of a single driver? Interesting.
    Stirling is gonna be squared away as everyone is when it comes to Polk CS, plain and simple.
  • AudioGenics
    dorokusai wrote: »
    I retract my comment regarding
    questionable quality control .
    My apologies to the QC folks
  • Stirling
    Stirling Posts: 22
    Update:
    I sent an email to both Crutchfield and Polk. They both responded. I actually got a call from Gil Pellerano and he told me he would try his best to fix this. I then got a email from Walter Moser and he said that a new driver would be sent out immediately...it arrived a day later. It was a very easy instal...actually took me longer to track down the correct Hex key. The driver was outside all day on my front step and its colder than a witches **** out there so I thought I would let it warm up first before turning everything on...but..yes great CS from both side of the border!
    S
  • dorokusai
    Walter rulez, keep him on on your radar and props go out to Gil as well. The support structure of Polk is NOT a fake out....it's beyond HQ.
  • falconcry72
    Stirling wrote: »
    Update:...he said that a new driver would be sent out immediately...it arrived a day later. S
    Doesn't get much better than that!
    Enjoy your now perfect Polks!
  • Sherardp
    Sorry for the delay Stirling, but I see F1 got you taken care of. Glad the A9's are back to business and your enjoying them.
