Best tube integrated amp from $500-1200
JimBRICK
JimBRICK Posts: 1,543
edited December 2010 in 2 Channel Audio
I'm going to be building a new 2 channel rig soon and I'm going to start with an amp and build around that. What tube amp do you guys think would be a solid foundation to start with. New or used in the $500-1200 price range?
I had the av123 sp3 and loved it before. I just wanna know what else I can look into as well.
thanks in advance
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Post edited by JimBRICK on
  • george daniel
    george daniel Posts: 12,096
    Dunno what kind of speakers you'll be driving,but my votes would be,,used of course,,Manley Stingray or a Rogue Cronus.
  • markmarc
    markmarc Posts: 2,309
    I would highly recommend Vista Audio I-34 if you go new, as they are never found used.
    I used to own the SP3 (loved it BTW), and I-34 bested it in many ways, resolution is greater, mids are more natural with less syrup.
    Former Staff Member TONEAudio
    2 Ch. System
    Might be just me, but I would settle on speakers first,so I know what I need to drive them with.
  • Ricardo
    Ricardo Posts: 10,634
    tonyb wrote: »
    might be just me, but i would settle on speakers first,so i know what i need to drive them with.
    + 1,000
    SOPA
  • JimBRICK
    these are the speakers I was looking at
    http://www.martinlogan.com/products/purity
    2 CHANNEL
    Under construction
    Nice Jim, but do you think a 500 buck integrated will do these up proper ?
  • WilliamM2
    WilliamM2 Posts: 4,808
    The Purity's have a built in 200 watt per channel amp. As far as I know, there is no way to bypass it. It has line level and speaker level inputs, but uses the internal amp either way.
    You only need a pre-amp.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    Buy a pair of used source for $1000 used
    I have them and love them
    You could buy vistas for $4500 new or $2300 used or just wait like me until march for the new electromotion that has the same size of electrostat panel as the vista but only costs $2000 new
  • dorokusai
    dorokusai Posts: 25,576
    markmarc wrote: »
    Probably because they sell about 1/100th of the SP3.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    I would consider some of the Joule gear.
    RT1
  • zingo
    zingo Posts: 11,258
    All you need is a good tube pre as they are self powered as mentioned above.
    zingo wrote: »
    Was trying to get him to come to that conclusion, you spoiled my fun man.:biggrin:
