Need help with Dual 622 and Denon DP-33f turntables
knobbie
knobbie Posts: 5
edited December 2010 in 2 Channel Audio
First, I have a Dual 622 which now only works in the manual mode. Can not see an easy way to remove the TT from the base in order to work on it. Anyone familiar with this unit? I also need the manual.
Second, I just picked up a Denon DP-33f TT. The pitch is slightly off but I can see no way to adjust. There are no controls to do this on the top. Any does anyone have any experience with this unit? I need a manual as well.
Any help on these units would be appreciated.
Thanks, Richard
Post edited by knobbie on
  • TomB
    TomB Posts: 106
    I downloaded a service manual for my Denon DP-31L turntable from vinylengine.com.
    I took a quick look at the site this morning, but it didn't look like they had the DP-33F manual - perhaps you had already tried there.
    It also looks like the have the Dual 622 service manual - in German!
