Center Speaker Mount
l330n
Im an trying to find a mount for my TL1600 Center Speaker for above my tv. I need to be able to angle it downward a lil bit, my tv it setup a little high and if what i have read i hear that your front speakers should be aligned with the center speaker. (Is that true?). Plus my wife deosnt want me putting anything on the fireplace shelf. :mad:
Are you wanting to mount it on the wall? Or attached to the TV in some way?
If it is a wall mount, you might look at this:
http://www.amazon.com/Pinpoint-Center-Channel-Speaker-Mount/dp/B002MP5JX4
If you want to mount it to the TV itself, there is something called a TV 'top shelf'.
http://www.amazon.com/OmniMount-Television-Top-Shelf-CCH1P/dp/B0007QVXLC
In either case, you should be able to put something beneath the rear of the speaker to angle it down. -
I want to mount my CSI A6 on the wall below my television. Does anyone know of any mounts that will hold the monster effectively? I know a machine shop that can custom make me some brackets, but this is a bit more costly than I would like. I guess if there is not good brackets out there, if anyone else wants some custom made let me know. Once I have the plans drawn up and 1 made, they are cheaper after that.
What about a simple wall mounted book shelf? It probably wont be as sleek as a custom mount but it would do the job and possibly offer additional storage if needed.HT:
TV: Samsung UN55C8000 | Player: OPPO BDP-95 | Games: Xbox360 / PS3 | Party Music: Squeezebox Duet
Mains: LSi15 | Center: LSiC | Surrounds: LSiFX | Sub: SVS 20-39pci
Pre-Amp: Outlaw 990 | Power-Amp: Outlaw 7700
Cabinet: Salamander Synergy Twin 30 | Speaker Wire: Lowes 12AG w/ monoprice banana plugs -
thought about it. I am blown away that there are not any out there
