Passive Rad.
Neskahi
Neskahi Posts: 297
edited December 2010 in Vintage Speakers
This may have been discussed at sometime but what will we do when
our passive radiators wear out? :eek:
SDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 1C/Solens/RDO's [gave to my Uncle]
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
M91 x 2 Pioneers/C91 Pre
Yaqin MC10l
DCD-1520/1560/2560 Denon
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2
Post edited by Neskahi on
  • dorokusai
    dorokusai Posts: 25,577
    When they reach age 65.
  • thsmith
    thsmith Posts: 6,082
    Neskahi wrote: »
    Roll in the spare:wink:
  • AudioGenics
    AudioGenics Posts: 2,567
    passive radiators are very reliable and seldom fail.
    but they are not perfect and when they do fail
    they can be replaced, repaired very easily
    There are also aftermarket replacement available
    if the original are difficult to find.
    Sometime modifications would include changing the passive to
    an active real speaker driver which would include crossover changes
    and cabinet mods.
    Nothing really to be concerned about.
    by the way what kind of Passive Radiator do you have and what size
    and from what make and model ?
  • Neskahi
    Neskahi Posts: 297
    Dont have any bad ones yet but just thinking about that day when I may need a
    SW150 or SW155 for the 1.2TL and 2.3TL. They just dont seem to show up on e-bay like
    the SW120 and SW121.
    SDA 2.3TL/Stock..
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    Yaqin MC10l
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • AudioGenics
    I would call POLK Customer Service
    and ask if they stock replacements PR of the types you mentioned
    and also the rest of the speaker drivers Mid/Bass and tweeters....
    and how long they plan on
    BUT
    if they do not
    Then
    you'll have to devise a contigency plan........
    Can it be REPAIR
    Can you find a replacement
    Can you modify
    etc.....
    Customer Service & Tech Support:
    polkcs@polkaudio.com
    1-800-377-POLK (7655)
    9AM-5:30PM EST Mon-Fri
    (410) 764-5470 FAX
    International +1-410-358-3600
  • dorokusai
    NO PR's are available from Polk Audio for the SDA and haven't been for a long time. That's why I buy them all the time off eBay and here. I probably have 20 or so in storage.
  • ben62670
    ben62670 Posts: 15,969
    ...Sometime modifications would include changing the passive to
    and cabinet mods.
    Real bad advice. Never run an active driver in place of a passive.
    Ben
  • Neskahi
    Neskahi Posts: 297
    Ah ha! Our new best friend.
    SDA 2.3TL/Stock..
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    Yaqin MC10l
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • Neskahi
    Neskahi Posts: 297
    Referring to Doro's stash in storage.
    SDA 2.3TL/Stock..
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    Yaqin MC10l
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • dorokusai
    Having and giving are too different things man.....it's part of the larger picture for when you guys are desperate :wink:
  • halo71
    halo71 Posts: 4,606
    May be a dumb observation on my part. But with the rubber surrounds on Polk PR's. And baring a child sticking something through the cone, cats clawing them etc. What else is there to go wrong?
    --Gary--
  • dorokusai
    It's not a dumb question Halo. I've seen spiders seperate, magnets drop off, fabric deteriorate, the glue detach from the PR "plate", the surrounds get so loose they fall out of spec....all kinds of things.
    They are rare to find in some sizes, 15" for example, and my suggestion is if you plan on keeping your SDA's or Monitors....you seriously think about spares. Polk has no plans to stop production support of the older products(RD-0194/8 and 3 MW series mid-bass drivers) but at some point that is going to happen. I'd rather be fat and happy than struggling to find something I need.
    I've tried for the last couple years to get Polk to work with me on a replacement or at least chamber a suitable replacement from another manufacturer and they're not interested....and very busy with other things which I understand. I'd rather see the new LSiM series than a new PR, so you'll get no complaint from me overall.
  • halo71
    halo71 Posts: 4,606
    Well in that case.....anyone have 2 Mon10 PR's to trade for 2 12" SDA PR's?:biggrin:
    --Gary--
  • dorokusai
    Maybe. What's the model number on yours? and the Mon10 PR will vary a little.
  • halo71
    halo71 Posts: 4,606
    I'd have to pull the PR's, got em in a old set of ESS cabs right now. The Mon10 PR's, I think are SW120?!?
    --Gary--
  • dorokusai
    I'm not sure about that model number but PR history is not my strong suit at all.
  • halo71
    halo71 Posts: 4,606
    I will probably just hold onto the 12" PRs for the time being. Although not original to the ESS speakers they have somewhat brought them back to life.
    --Gary--
  • dorokusai
    Hey, keep them going and working. Enjoy!
  • AudioGenics
    ben62670 wrote: »
    I agree.
    It was bad advice and not a good recommendation
    I have seen where the passive radiator was replaced with an active driver.
    The bottom section of the speaker cabinet was "walled internally"
    and the passive Xover completely removed although a modified Xover
    could also work but in this case
    An adjustable active Crossover was used to bi-amp.
    The mid/bass was to be more of a midrange.
    A small coil and cap for the tweeter inserted inbetween
    I think this is what one would call a Frankenspeaker.....
  • dcoil
    dcoil Posts: 153
    Wow, and I was thinking of hoarding oil stocks or guns.. Now I'll be on the hunt for spare PR's:biggrin:
    SDA SRS modded: X’ovrd, de-polyed, inductorized, interconnectorized, re-posted, dynamited, RDO’d, spiked, gasketed, ringed (Larry's), and grill cloth blinged! Done this on my own? Not a chance. Thanks to Raife and all who forged easy to follow upgrades. At least a 100% improvement in sound and my personal listening pleasure! :cheesygrin:Pass XP-10 preamp, Parasound A21 amp, Pioneer Elite DV-58AV (Ric Shultz modded), Audioquest Sky IC's, No longer need my Sunfire sub after mods...
  • codyc1ark
    codyc1ark Posts: 2,532
    ben62670 wrote: »
    Didnt we just see this on a set of SDA's in MN recently on CL? I can't remember exactly where. I thought it was the way to go, need that BASS!!
    :wink:
  • skrol
    skrol Posts: 3,393
    dcoil wrote: »
    If he follows the law if supply and demand, the PR's may turn out to be the wiser investment.:wink:
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • thejck
    thejck Posts: 849
    Nekashi,
    You get a new set of 1.2TL's since I last showed up at your doorstep?
  • Neskahi
    Neskahi Posts: 297
    Yes we did. Found a good deal in Dallas and we were going that way anyway.
    You still liking yours?
    SDA 2.3TL/Stock..
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    Yaqin MC10l
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • Neskahi
    Neskahi Posts: 297
    And I think you had your eyes on them too but they were too far away for you.
    SDA 2.3TL/Stock..
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    Yaqin MC10l
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • thejck
    thejck Posts: 849
    i now have a set of 1.2's that ben's upgraded to TL's and i love them.. cant wait for the crossovers to break in.
    i missed out on that 1.2tl deal in denver that went for 500 bucks by 5 minutes. Think Larry spoke to the guy later that evening.
    Dallas is a bit out of my scope.. let me know if you feel like selling them.
