RTi28 vs. RTi38
brianwayne671
brianwayne671 Posts: 41
edited July 2003 in Speakers
I currently have the following setup:
Receiver Harman Kardon AVR225
Mains Rti28
Center CSi30
Surrounds FXi30
Sub PSW303
My question is this, my receiver has a non-adjustable crossover of 100Hz. If I was to upgrade my mains from the RTi28's I currently have to the RTi38's, will I notice any significant difference? Reason being, my thought is that the 38's may play a bit lower, but the sub cuts off everything below 100Hz anyway right? Also, will the 38's overpower the CSi30? I use the setup for 90% movies and 10% music. Any thoughts?
Thanks,
Bri
Post edited by brianwayne671 on
    VR3 Posts: 29,549
    edited July 2003
    I have the RT35i (RTi38) and the CS245i (CSi30), and my PE also cuts them off at 100hz. Although I believe that is the surround speakers it cuts off. Because on God's green earth my mains play atleast down to 50hz!!! There is no way that woofer moves that much on 100 and play that much bass. But no the 38 will not over power your center.
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2003
    Nice setup and hello. :)
    No they will not overpower your CSi30.
    The larger speaker, RTi38 will give you some more volume, and punch than the RTi28. It is easier to drive than the RTi28, IMO. That little RTi28, is a very nice bookshelf speaker.
    Is your non-adjustable crossover for the subwoofer? Or for your mains, or all? Do you have speaker size settings that are selectable on your receiver, example...large and small?
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited July 2003
    Sid, the crossover is not a brick wall. It is a fairly gentle slope (probably 12 dB/octave). So an octave below 100 hz, your speaks are only -12 dB - still quite audible.
    If all your speaks are set to small, then you will hear bass down to at least 60-65 Hz from them with a 100 Hz xo.
    Doc
    SVS
  • brianwayne671
    edited July 2003
    Thanks Vr3MxStyler2k3, dorokusai, and Dr. Spec for the feedback. I wasn't aware that the crossover was not a true brick wall at 100Hz crossover (on receiver). So Doc, if I'm hearing you correctly, I will hear a difference in the lower and mid ranges by going with the 38's right? I have my setup in a smaller room maybe 12 x 15 or so in my apt. The 28's sound good, but do you guys think the 38's will sound even better? My thoughts are that it would prevent upgrade fever down the road and the difference is about $79 more dollars. I don't really need the extra volume, but what about sound quality. Some say the 28's are not good mains, but the seem fine to me. Thoughts?
    Bri
  • dorokusai
    edited July 2003
    It really is all subjective and up to you. The RTi28 is a great performer. The RTi28 with an even mediocre subwoofer, PSW202, are just fine for mains.
    Will the RTi38 sound better? Yes. Will it be like having the finger of a Supreme Being touching you? No.
    The RTi38's simply do what almost every larger cabinet, larger mid/bass driver speaker does. More bass punch, smoother midrange....but tweeter is the same, rolloff will be the same and on and on.
    Is it worth $79? I think so. I went thru this whole decision process just like you.
  • faster100
    faster100 Posts: 6,124
    edited July 2003
    I echo the above 2 post, I have the 38's as rears and they sound good, however as mains i think they would be even better, Great speaker and for 80 bucks extra, grab em. The 28's make nice surround speakers and if the need to crank comes along, friends over or a party.. the 38's will be louder and more solid.
    My o my, If i could find someone to buy this like new polk psw 404, Oh anyways.. its up to you in the end,
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • ChrisDurano
    ChrisDurano Posts: 372
    edited July 2003
    I don't think its worth it to move up just to RTi38's. You should wait until you can upgrade to something more like RTi70's, and even upgrade your center to CSi40. You'll notice even more improvement and you won't be wasting your money.
    Home Speakers polkaudio RTi70's (bi-wired), CSi30, FX3000i, PSW250
    Car speakers polkaudio EX 369, DB 650
  • dorokusai
    edited July 2003
    Chris - Naturally it would be inherently better to upgrade even further, but he looks as if he prefers bookshelf speakers for whatever reasons. I was not able to employ a floorstander due to the entertainment center covering the entire wall.
    The two in question are the RTi28 and RTi38. Yes the RTi70 is mighty fine, but to say its not worth upgrading to a RTi38, you may as well go further and say, why not hold off until you can afford some SDA 3.1TL's with a custom made center channel, etc.
    I try to stay focused on the original question and not read to much into it, just help answer questions and move on. I'm not busting your chops Chris, please don't take offense, its not intended. All posts are good posts in the quest for information.
  • faster100
    edited July 2003
    Are you somehow not happy with your 38's as mains? I just got a set as rears and actually would like to test them on the mains just to see how they sounded? maybe for a 2 channel down the road,
    Also he lives in an apartment and room is most likely at a premium, 28's or 38's will work great, bigger is almost always better to an extent with speakers and for only 79 extra its a no brainer, CC has a sale, the 28's are 79 cheaper then usual But the 38's are 100 cheaper, usually $379.00 for 279.00
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • brianwayne671
    edited July 2003
    Yes, I do prefer the bookshelf's. I had some floorstanders and they just overwhelm my small room, though they sound great. I am curious though as to why the guy who had 38's and fx3000i's would say it's not worth it to get the 28's? Do you not like them, or do you think it's just a minimal upgrade? It looks like we would have almost identical setups. What receiver are you using?
    Thanks,
    Bri
  • ChrisDurano
    edited July 2003
    Brian,
    I just think its a minimal upgrade to go to the 38's. When you get into a house, you should then upgrade. But since your in an apartment......save your money (I'm a mortgage lender) and get into a house. Then you can splurge. I'm happy with my setup...but I won't be upgrading until I get an HDTV. Then I'll get some bigger mains and throw the 38's to the rear.
    VR3 Posts: 29,549
    edited July 2003
    I reviewed the older models of the i28, and i38 here. It is long, but hey, it will give you an example.
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=10951
    The 25i's are placed as surround, but they still performed very well. Its worth a read, although it's long! lol!
  • brianwayne671
    edited July 2003
    I think I may just go ahead and save the $79 for now and possibly upgrade the receiver, or not. I see that although alot of people say that the 6 1/2" driver is much better, it looks like the LSI series everyone loves so much only use 5 1/4's? The 28's seem to do fine for mains right now. They are plenty loud and blend well with the sub which picks up the lows. Leaving my setup as is also means identical 5 1/4" drivers all the way around. It seems many people with even larger rooms than mine utilize sub/sat combos which use much smaller drivers. For the moment, I think I'll stay put. But I've been known to change my mind at the last minute! ;)
    Thanks,
    Bri
    VR3 Posts: 29,549
    edited July 2003
    You are right about the LSi. However the LSi use a much higher quality driver than that of what is in the RT line. The RTi28 is a fine speaker, enjoy.
