Another PSW505 Setup Question
Meatball
Meatball Posts: 3
PSW505 just arrived today and man, it looks great. I've got it paired with a Yamaha RX-V367 Receiver, 2 Polk Monitor 40 Series II Bookshelf's for front surround and 2 Polk RM6751 Satellites for rear surround.
I followed the Recommended setup and turned off the Sub in the receiver and wired the front surrounds to pass through the sub first. I can hear the sub a bit, but not all that much, so I'm wondering what other settings I should check.
The RX-V367 does have Sub-Out, should I just use that and direct wire the front satellites? If so, I'm not sure if I should use the right/left unfiltered or LFE filtered in?
Any other tweaks I should mess with on the Phase or Low Pass?
Thanks!
  • cnoat
    cnoat Posts: 315
    edited November 2010
    Meatball,
    Try using the lfe.You will hear a big difference.Also set your reciever to small for the fronts.If you have crossover settings set them at 80.Oh yea welcome to cp the best audio forum on the net.
    Parasound Avc-1800
    Mains-Rti 12 -Parasound 1500a
    Center-Csi5-Parasound 1000a
    Rears-Rti 8-Parasound 750a
    Sub SVS Ultra Tv 12
    Diamondback and King Cobra IC's
    AQ T4 SC
  • cnoat
    cnoat Posts: 315
    As far as the phase use your ear.That is the best judgement.
    Parasound Avc-1800
    Sub SVS Ultra Tv 12
    AQ T4 SC
  • Meatball
    Meatball Posts: 3
    Awesome, thanks! I'll give that a shot. I really wish they'd have made that the 'Recommended Setup' in the manual so I didn't spend half an hour running all those extra wires :)
  • cnoat
    cnoat Posts: 315
    YVW.Keep us posted.
    Parasound Avc-1800
    Sub SVS Ultra Tv 12
    AQ T4 SC
  • Meatball
    Meatball Posts: 3
    edited December 2010
    Finally got around to redoing the cabling, used a single RCA cable with the Sub Out/LFE and it sounds much better! Thanks!
  • pit495
    pit495 Posts: 3
    Need some advice on my psw504. I received the sub about three weeks ago and just love the sound. today there was a loud shrieking sound coming from the speaker. i was able to duplicate the noise by moving the lfe cablein the rear of the speaker. i feel that the connection going to the back of the speaker probably is not snug enough. My question is can i use a regular RCA cable, i have few high quality ones hanging out in my basement, or does it have to be lfe specified?
    pit495:biggrin:
    A regular RCA cable of quality will work...has to be long enough though.
