Christmas lights, I don't get it...
steveinaz
steveinaz Posts: 19,545
edited December 2010 in The Clubhouse
How come, if you take a bad bulb out, you'll lose power to some of the lights---BUT---if you put the bad bulb back in, they'll light back up? Wouldn't a broken filament mean an "open" circuit, just the same as removing the bulb completely?
I'm baffled. :confused:
Post edited by steveinaz on
  • Willow
    Willow Posts: 11,231
    edited November 2010
    Maybe so you can't stick an object in and get shocked
    treitz3 Posts: 19,992
    Page 2, section 4, paragraph 15 should explain it.
  • bobman1235
    bobman1235 Posts: 10,822
    Sometimes when the filament breaks, the two things that were HOLDING the filament are either touching or close enough to carry a current. It doesn't take much.
    EDIT just a guess, btw.
  • madmax
    madmax Posts: 12,434
    I'll bet it either has more than 2 conductors to the bulb OR it fails in a shorted condition.
    Vinyl, the final frontier...
  • Rev. Hayes
    Rev. Hayes Posts: 475
    Aren't a lot of christmas lights run in a parallel circuit?
    Sounds good to me...
  • shadowofnight
    shadowofnight Posts: 2,735
    The older light strings used to mostly use a series wiring setup ( One die/all die ), newer ones tend to use a few different types.
    http://www.wisegeek.com/why-does-an-entire-string-of-christmas-lights-fail-when-a-single-bulb-burns-out.htm
    The first rule of Fight Club is you don't talk about Fight Club
    mhardy6647 Posts: 35,015
    I think that the longer strings of the "subminiature" incandescent lamps (which, if memory serves, are 3V filaments) are wired series parallel. For example (and just for illustration!), a hypothetical 120 lamp string might have three series strings of lamps (40 each), and those three strings might be paralleled to plug into the mains outlet. Each series string would drop 120 volts. A lamp failing in one series string would break continuity in that string; those 40 lamps would be kaput... but the other two would still light.
    That said...
    Many modern (so to speak) strings of the subminiature bulbs had shunts in the sockets; if one lamp burns out, the shunt conducts the juice instead of the filament and the series string stays lit.
  • steveinaz
    That's what I was thinking, sort of a "quasi-parallel" setup or something. Wierd.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    steveinaz wrote: »
    You live in the SW - why not go 'old school' and make faralitos (aka luminarios)? :biggrin:
    Tony M Posts: 11,623
    Think of the letter H,
    With the top having the filament that lights. The middle piece always carries the current.
  • George Grand
    George Grand Posts: 12,258
    This is the type technical description the world yearns for. Good man.
    I thought for sure the thread would be about Christmas lighting. The guy next door to me makes Clark Griswold look bad.
  • maximillian
    maximillian Posts: 2,149
    I think the shunts are in the lamps. If you pull a burnt lamp (where the string is still lit) then the string goes out.
    tonyb Posts: 33,072
    Christmas lights are like picking up a ****, just no good way to handle them.
  • inspiredsports
    inspiredsports Posts: 5,502
    I think they used to call it a "shunt" type bulb used in old series wired light strings. A solid shunt wire is present in addition to the filament that can/will burn out. The solid shunt stays put keeping the string lit.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Bingo.
    Even I understand now.
  • steveinaz
    GOT IT! That makes perfect sense.
