Can I use an AVR as an amp?
squeeb
squeeb Posts: 426
edited December 2010 in Electronics
Just wondering if I could use an AVR I have laying around as an amplifier? I would use it to power second fronts on my Sunfire until I can save for an appropriate amp.
Could I run the l/r from the Sunfire side axis speakers to the aux in on my Denon and then set the Denon as stereo / no sub?
Thanks.
7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi
Post edited by squeeb on
  • thuffman03
    thuffman03 Posts: 1,325
    edited November 2010
    I guess you could if you really wanted to. You might have to hold two remotes to keep the speakers in sync for volume with the ones powered by the TGR.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • AudioGenics
    AudioGenics Posts: 2,567
    not really recommended
    best to sell the AVR
    and upgrade
  • WilliamM2
    WilliamM2 Posts: 4,806
    Why do you want two sets of front speakers? I wouldn't do that with a receiver or an amp.
  • squeeb
    squeeb Posts: 426
    and upgrade
    Yea - I have the AVR up for sale and will use funds to buy amp. I thought I could try the AVR to see if I liked the sound or thought it was worth getting.
    WilliamM2 wrote: »
    The Sunfire has the capability to have side axis speakers (powered by a separate amp) to have a 9.1 (actually up to 9.3) HT. I have an extra set of matching speakers laying around and thought I would see if it made any difference in sound. Sunfire states it is to help fill in the gaps between the fronts and surrounds.
    Obviously, I do not want to hurt any equipment in my experiment.
  • squeeb
    squeeb Posts: 426
    From the TGR3 manual ...
  • LeftCoast
    LeftCoast Posts: 406
    squeeb wrote: »
    Is that similar to the Audyssey fronts and front wides?
  • squeeb
    squeeb Posts: 426
    Not sure if it is like Odyssey or not. I would imagine it is similar though.
  • Monster Jam
    Monster Jam Posts: 919
    Wow - 9.1. Thats (counting my fingers) NINE speakers. Impressive. I don't have room in my loft for the five I have set up.
    Do you hear that buzzing noise? :confused:
